09-13-2009, 01:12 PM
Anything but Senior
Time to rebuild the brakes, I guess...
On my '67 Spider, the passenger side front brake had started making a noise, just like it was dragging a little under speed. It would go away in turns, which did not make sense to me. Took the wheels off , and tried to feel for wobble of the hub...it all felt tight. But the discs look bad, many deep grooves. And the wear pattern of the passenger side outer pad is the weirdest I have ever seen, see the picture.....Also, I see rust on the pistons. So I guess I'll rebuild the calipers, see if the discs can be machined (although with the deep grooves on both sides, I highly doubt this is even an option, anyone have the minimum thickness handy?).
Stupid question, this is the first time I've taken the hubs off of a 105 Alfa. The nuts holding the bearing were only finger tight (the nuts at the end of the spindles)...I guess that's normal, because otherwise the bearing would not be allowed to spin??
About repacking the bearings, I guess it's just clean off the old grease, and put in a ton of new grease?
I also want to replace the old flexible brake lines, what do you guys recommend using?
On a positive note, the rear brakes looked fine. It was a little hard to turn the wheels, but I guess that's because I just took the handbrake off, and the would free up more as soon as you start driving
Peter
Currently:
'69 Euro 1750 GTV
'91 164L (my son's)
Previously:
09-13-2009, 02:22 PM
Slo-Mo Restorations, Inc.
Originally Posted by Peter
[...]anyone have the minimum thickness handy?).
10 mm. If I understood the convoluted language in the shop manual, you can't grind off more than 1 mm (e.g. 0.5 mm each side).
Stupid question, this is the first time I've taken the hubs off of a 105 Alfa. The bolts holding the bearing were only finger tight...I guess that's normal, because otherwise the bearing would not be allowed to spin??
Not sure what you mean by "the bolts holding the bearing". You mean the nut at the end of the spindle or perhaps the countersunk screws in the brake disk hat?
'99 166 3.0 (La Divina) // '72 Montreal (La Tempesta)
09-13-2009, 02:29 PM
Anything but Senior
thanks for your reply....sorry for my poor choice of words, I meant the nut at the end of the spindle (original text edited for clarity)
Peter
Currently:
'69 Euro 1750 GTV
'91 164L (my son's)
Previously:
09-13-2009, 04:05 PM
Anything but Senior
Looks like I'll be needing new rotors. I'm seeing that earlier cars, like my Duetto, are supposed to have smaller rotors, like 266,7 mm....My duetto may have been converted, as I measured my rotors and they are like 271 mm....is that the larger size that was used on 1750 and 2000 cars??
Peter
Currently:
'69 Euro 1750 GTV
'91 164L (my son's)
Previously:
09-13-2009, 04:22 PM
This nut only need to hold the outer bearing in place by exerting a slight pressure on the perforated washer, i.e. prevent the bearing from moving outwards. The outer bearing is set in a tapered hole in the hub and can't move inwards. I'm not sure what would happen if you really tighten the nut, but I can imagine that the race in the conical bearing will press against the balls and prevent them from rolling freely. I have both hub assemblies in pieces on my workbench right now, but I havent had time to study them. Corrections are welcome ... !
09-26-2009, 03:32 PM
Anything but Senior
so finally putting her back together. Rebuilt calipers, with some fresh paint, cleaned and painted the hub, some fresh black paint here and there, cleaned the bearings and repacked them with fresh grease.....
Peter
Currently:
'69 Euro 1750 GTV
'91 164L (my son's)
Previously:
09-26-2009, 03:39 PM
Anything but Senior
new grease seal in place, hub mounted on the new disc, some grease around the spindle, assembly in place, calipers mounted with fresh pads. Also replaced the brake lines. It's not a concourse job, with all the paint in correct colors....but it's functional, and I like it
Peter
Currently:
'69 Euro 1750 GTV
'91 164L (my son's)
Previously:
09-26-2009, 03:45 PM
Anything but Senior
so now I need to bleed the brakes. I have not done this before on my Spider. Opened the brake fluid reservoir, and it's different from my GTV's. See the picture of what cardisc calls sealing bellows.....the was brake fluid in the bellows, isn't it supposed to be below the bellows only? If so, are these prone to leaking and easy to replace, or NLA? Have not had an issue with this, but I guess it's supposed to help keep moisture out of the system?
Peter
Currently:
'69 Euro 1750 GTV
'91 164L (my son's)
Previously:
09-27-2009, 06:36 AM
Nice job! What's that paint on the hubs? Hammerite?
09-27-2009, 10:12 AM
Anything but Senior
I used a spray can of Rustoleum Hammered finish. Came out really nice
Peter
Currently:
'69 Euro 1750 GTV
'91 164L (my son's)
Previously:
09-27-2009, 12:44 PM
Anything but Senior
still dragging!!!
OK, so I bled the brakes. They feel really good, brake fine. Got them warmed up gradually to properly bed the pads. All is well, except I can still hear my front brakes drag a little.....drove around for about 20 minutes, thinking things just needed to settle....but they are still noisy. Any idea what I did wrong?
Peter
Currently:
'69 Euro 1750 GTV
'91 164L (my son's)
Previously:
09-27-2009, 06:41 PM
I'd let it sit overnight to let any small residual air bubbles work their way to the reservoir, then bleed again. Make sure there isn't too much fluid in the reservoir; not enough air space can cause the pistons to not move back as much as they should.
What flexible brake lines did you use? Steel braid over rubber or oem-style rubber?
Nice clean job.
09-28-2009, 06:06 AM
Anything but Senior
Thanks for your reply. I used OEM style rubber lines.
Peter
Currently:
'69 Euro 1750 GTV
'91 164L (my son's)
Previously:
10-01-2009, 07:08 AM
Anything but Senior
Peter
Currently:
'69 Euro 1750 GTV
'91 164L (my son's)
Previously:
10-01-2009, 07:42 PM
Membro Maggiore
Peter
Yeah you don't want that big nut at the end of the spindle to be tight. Not sure the procedure on your car. I keep my wheel spinning and tighten it pretty firm and then back off with the wheel never stopping. Tricky. But this makes sure the bearings seat properly. Finger tight for the end result may be too tight for some applications. If it is too tight while the wheel is stopped you will get Brinelling in your bearing races, and then noise, followed by sadness.
Larry
Hartselle, AL
Director, Alabama Branch, SNO
Help for the Confused and Incorrect since 2009
When men such as Captain Larry absconded to the Florida Keys, they left behind a myriad of tall tales and unbelievable stories.
