06-22-2009, 06:01 AM
No problem Alex, will do.
1974 Spider 2.0L
06-22-2009, 07:00 AM
...in the Garage...
Any brake fluid found in the spring chamber portion of the valve indicates that the cup seal has failed. These seals should be replaced before re-assembly or (and this depends on the extent of the leakage) the valve may not function at all as intended. Ideally O rings should not be used to replace cup seals.
06-24-2009, 05:14 AM
Shed troglodyte
I talked to the guys at CBC today and unfortunately they didn't keep a record of the sizes or sources of the parts used to rebuild the PV. I didn't think that they would as it was such a small job, so many months ago.
What I'll do now is buy another one and pull it apart. I'll let you know how I get on.
Chris
Own - 1970 1750 GTV
Want - 1969 Duetto (in addition)
Also own - various other Italian and German rotboxes
06-27-2009, 03:04 AM
Finally i had some time to pull it all apart, unfortunatelyI had rust and it is pitted, and found brake fluid in the chamber.
CBC Bearings at Kingsgrove (head office) had the O'rings but didn't have the correct cup seal.
Chris what state are you in?
O-ring size
26X2mm =$0.27
12X2.5mm = $0.12
I have sent the value to get it re-sleeved with stainless steel and they will supply the cup seal. I also asked for part numbers of all seals, should you guys want some.
Rich
1974 Spider 2.0L
06-27-2009, 04:54 AM
Shed troglodyte
Rich
I'm a cane toad
I've bought another secondhand valve. When it arrives early next week I'll pull it apart and get it measured up. Hopefully it won't be too badly corroded.
Rich, thanks for your good work so far. The CBC guys here are really nice blokes - very helpful.
I'm sure that the piston cup seal will come up somewhere again - if not they can be made, but the manufacturing run might need to be 10,000 to make it worth while for the rubber extruder .....
Chris
PS: I just realised your car is a 2000 Spider, not a Duetto. Either will do
Own - 1970 1750 GTV
06-30-2009, 04:49 AM
Shed troglodyte
The second hand PV arrived yesterday and I pulled it apart last night. It wasn't badly corroded at all, though it was covered internally in a sort of varnish. All of the seals were kaput and the cup seal split as I tried to carefully remove it. I've measured everything as below.
The O-rings were as Rich described and I haven't bothered with them any more as they are commonly available.
Dimensions marked on the piston are :
A - 12.00mm
B - 5.90mm
C - 12.65mm
D - inner 4.00mm, outer 4.50mm (there is a small 0.50mm step that is visible in the photo)
The cup seal has an outer diameter at the flared end of 13.00mm
For our USA subscribers, I'm sorry but this seems to be a metric component so all of the dimensions are in millimeters.
Now the hunt is on for the piston cup seal. I'll take this part up to the guys who helped me last year and see if they can recreate the magic.
Hope this helps,
Chris
Own - 1970 1750 GTV
07-02-2009, 07:29 AM
Bad news, the guy from Marion Brakes & Clutch called me today to tell me they can't fix it, it's too pitted and the can't get the seals, *&^&%%$.
Chris, now that you have spare, do want to sell PV to me? Otherwise can you tell me from who you purchased it from?
Rich
1974 Spider 2.0L
07-02-2009, 10:04 AM
What does the cup seal look like?
Lots of eyes on here can help source the part. Might come from another brake assembly. Send an inquiry to White Post Restorations. They do a lot of brake restoration work and might have a source for this part. I have read pro's and con's about White Post work, but that is for another thread.
07-02-2009, 11:25 AM
Certified Oldschooler
You can get them new from Alfaholics, perhaps elsewhere. I have no idea if the spring/pressure settings are the same. Where would find PV setting specs on the various years??
Now - '69 1750 Spider Veloce ( pictures)( and more) 10562.1480323 (since '75 for that early mid-life crisis!);
Gone - '69 1750 Berlina (wish I still had)
07-02-2009, 06:20 PM
Shed troglodyte
PV cup seal dimensions
OK - I'll do my best here.
There are 3 photos below - one each of the top, side and underside of the cup seal.
The dimensions are as follows -
Top view: OD flared end 13.00mm, OD non-flared end 12.50mm, ID 5.50mm
Side view: Height at outer margin 3.20mm, height at inner margin 3.50mm, height of central part 3.90mm. Flared & non-flared end dimensions as above.
Underside: Thickness of seal rubber 1.20mm
On the underside, it is marked '13-H Ate' and '45386'.
Please bear in mind that even though my hand is steady, my eyes sharp and the digital verniers I use are of the best quality, this is an old split seal so there may be some minor variance in these measurements. (What's the old saying - a poor carpenter blames his tools  )
At present, I can't part with this one as it is about to be hawked around in order to find parts. Rich, try any of the secondhand Alfa parts dealers, though you may have to buy a couple before you get a good one. I think I got lucky with this one - and also with the seals a year ago, it seems.
Hope all of this helps,
Chris
Own - 1970 1750 GTV
07-02-2009, 11:51 PM
That seal "almost" looks like a seal from a master cylinder kit, but on a much smaller scale. Thank you for taking the time to post the photos.
07-03-2009, 12:01 AM
Shed troglodyte
Yes - very much so.
If it can't be found in the auto shops, maybe the motorbike fraternity can help - motorbikes have small master cylinders, don't they?
I keep wondering why this thread has generated such interest. Am I the first person to have dismantled one of these valves?
On a lighter note, one of the hydraulic shops I've visited suggested that if I couldn't find a kit, maybe I could just carry a couple of bags of concrete in the boot (trunk) as that would keep some weight on the rear wheels during heavy braking ..... Ha ha ha - cunny funt.
Chris
Own - 1970 1750 GTV
07-03-2009, 05:19 AM
I come, I see, I concrete!
Highwood sells them for 75 pounds new, I have decided to save myself the aggravation and buy a new one, the only thing though it is smaller in size and Chris said that i may need a longer pipe line, which isn't a problem because i made all new brake lines myself and re-chromed all the fittings.
Thanks for your help Chris1750
1974 Spider 2.0L
07-03-2009, 01:31 PM
I am rebuilding one of these too. I have talked to a local shop and they gave me a seal to try. I have already sourced the 2 O-rings local. I should have it put back together today and see how it works.
Current:
fast 1969 Berlina back to DCOE's
faster 1991 BMW 318i
fastest 1987 CBR1000
Past
1974 Spider
1979 Spider
1978? Alfetta
07-03-2009, 04:27 PM
Lots of PV Threads
Chris
Chris, there are dozens of Threads on brake proportioning valves. Try a search using "proportioning". Some have pics of them dissected. I've taken two apart. Most folks seem to just either just clean them or replace them - with stock, or with an adjustable valve (Tilton, etc.) since they are still available. Here is but one good example - LINK. Like I said above, a 73 used one seems to be working fine (so far) on my 69, and I have a new spare form Alfaholics (for US$ 108 with shipping) for my next brake work session. Cheers,
