Old 04-29-2009, 08:39 AM
Farace's Avatar
La Dolce Veloce
Speedbleeders
I know these things have gotten much praise here in the past. I'm going to add to it anyway. I've had a spongy pedal the whole time I've owned my Spider. I know it shouldn't be this way; automotive journalists at the time the car was built praised the Alfa's brakes as being better than any save for the Pantera. No, this couldn't be right. So what did I do? I bought a Gunson Eezibleed. Didn't help, no doubt partly because it's damned near impossible to get a good seal on the master cylinder due to there being three caps that have to maintain pressure.
I hesitated to get Speedbleeders because it seemed like a lot of money for some fancy bleed screws. But I finally broke down and bought some. I'm glad I did. Alfa recommends bleeding a front and rear caliper simultaneously (at least on 105/115 vehicles, and probably on others). Kind of hard to do with two persons, impossible with one. With the Speedbleeders installed, all I had to do was crack a front and rear, put drain tubes/catch cans on both, and pump away. Close them up and repeat on the other side. No helper needed (wife now being ex-wife, son being only six, helpers can be hard for me to come by anyway). Ten minutes later, I've got the firmest pedal I've had in the five or six years I've owned the car. Any of you guys still fighting a spongy pedal, give these a try, and bleed a front and rear at the same time. (I was tempted to bleed all four wheels simultaneously, but I didn't know if the pressure would favor one side over the other.)
Maybe I'll be able to learn to heel and toe now?
Bob Farace
1987 Alfa Romeo Milano Gold
Director, Connecticut branch, Scuderia Non Originale
Old 04-29-2009, 08:53 AM
ECARRILLO's Avatar
Motor City
What type - brand did you buy?
Eliseo Carrillo
101.23....race car - 105.52....race car - 105.32....work in progress race car
Old 04-29-2009, 11:13 AM
Farace's Avatar
La Dolce Veloce
I didn't know there was more than one brand. The brand name is Speed Bleeder, their website is here: Speed Bleeder. Centerline sells them and there's at least one guy on eBay selling them. I would imagine they're probably carried at some auto parts stores, as well, since they're blister-packed on a hang card. The specific ones I got were (if my memory is working right) SB8125LL for the front calipers (8M x 1.25) and SB7100 for the rears (7M x 1.00). I also got one for the clutch slave but haven't installed it yet (can't remember for sure, but I think that one is SB6100; 6M x 1.00).
Bob Farace
Old 04-29-2009, 11:38 AM
Tifosi's Avatar
Darth Slacker
There's a few manufactures making them, but Speed Bleeders are the original, and IMO the best designed. (after all, they hold the patent so any others are either a licenced replica, a knock off or don't work quite the same way)
Be careful of that clutch one Farace. I dunno if I got a bad one or what, but finding a wrench to fit that little SOB was all but an act of God for me. T'wasn't metric, t'wasn't SAE. If I didn't know better I'd say it was a Whitworth wrench size (1/4" is about the closest I found)
Best bet: find a wrench that fits before installing it so you don't have to lay under the car with half a toolbox trying different sizes like I did.
Beyond that, they're the greatest thing since sliced bread. Just don't forget to put fresh neversieze on the threads every year or so like the instructions suggest.
Darren
as hosted by
Greg Gordon's HI Performance Store
Old 04-29-2009, 11:55 AM
Farace's Avatar
La Dolce Veloce
Thanks for the tip. I note their website states:
Speed Bleeders are made from one of these four hex stock sizes...
1/4" hex, 5/16" hex, 3/8" hex, 7/16" hex
This also applies to metric sizes. This means that metric wrenches will not work with Speed Bleeder even though it might have a metric sized thread. You have to use an inch wrench or SAE wrench size. The reason is that metric hex stock is not readily available at a reasonable price in this country.
So maybe the 1/4" was only approximate? I'll have to buy a cheap set of Chinese tools, because I find those sizes to be approximate as well, so maybe they'll fit exactly.
Bob Farace
Old 04-29-2009, 12:33 PM
rcess's Avatar
I just put a Speed Bleeder on the clutch slave cylinder of my '69 Spider last week, and yes, that wrench size was something else. Like Tifosi, I found that a 1/4" wrench worked.
Bob Cess
'59 Giulietta Sprint
'60 Giulietta Berlina
'62 Giulietta Spider
'69 Spider Veloce
Old 04-29-2009, 02:49 PM
TorW's Avatar
Slo-Mo Restorations, Inc.
The bleed screw hex is supposed to be 7 mm, which translates to .27 - .28 inches. If I'm right and your 1/4" wrench did fit, the wrench must have "gone Chinese" already
'99 166 3.0 (La Divina) // '72 Montreal (La Tempesta)
Old 04-29-2009, 03:28 PM
Farace's Avatar
La Dolce Veloce
The stock bleed screw is indeed 7mm, but the Speed Bleeder replacements are unfortunately made from standard-size hex bar stock in either 1/4", 5/16", 3/8" or 7/16", even though the threads are cut metric. It's not such a big deal, but I'll have to remember to grab the "other" wrenches when I'm bleeding the brakes and clutch.
Bob Farace
Old 04-29-2009, 04:09 PM
TorW's Avatar
Ok, I see. It never crossed my metric mind at all. I can definitely see the utility in having imperial heads and metric threads since "everybody" has imperial tools anyway.
I use a similar bleeder gadget; a clear plastic hose with check valves at the far end. Costs the equivalent of seven-something dollars, and the hose fits really tight on the bleed screw. I've used it to bleed both the brakes and the clutch alone.
Now, if someone could invent a Speed Bleeder-like bleed screw which could sit permanently on the car ...
Old 04-29-2009, 05:37 PM
Tifosi's Avatar
Darth Slacker
Speed bleeders do: they replace the existing bleed nipples outright.
Darren
as hosted by
Old 04-29-2009, 06:03 PM
rcess's Avatar
I'm quite aware the bleed screw is 7 mm, but... And I do have a pocket calculator.
Bob Cess
'69 Spider Veloce
Old 04-29-2009, 06:25 PM
Alex's Avatar
While we're on the subject, I've spoken to Richard Norris at Classic Alfa to produce extra early 105 brake fluid reservoir caps (at a cheap price) so that these can be fitted with a nipple to fit to the Eezibleed system, as this size is not catered for by any of the available sealing caps. He was positive on that idea, so watch this space.
Old 05-02-2009, 11:02 PM
BlpltGTV's Avatar
Send a message via AIM to BlpltGTV
I got a set of Russel Speed Bleeders from Summit racing for a grand total of $24.71 with shipping. Front part # is Rus-639620 (8mmX1.25) and the rears RUS-939570 (7mmX1.0) They work great.
Will
  #14 (permalink)
Old 08-25-2009, 08:45 AM
SurfCity Alfa's Avatar
Just wanted to cast my vote for the speed bleeders, I just received a set from Centerline yesterday and put them in and bled the system last evening...great results, best (shortest) pedal travel I've ever had...
Surfcity Alfa
72 GTV
  #15 (permalink)
Old 08-29-2009, 10:14 PM
Alfapwr's Avatar
I got them for the Super racer too. Real easy to use. Bought from Centerline.
__________________________________________
Dan Walker
Stevenson Ranch, CA
67 Duetto ( Baci )
67 Giulia Super race project ( la scatola della merda di volo )
Spend more money and your wallet is lighter, and lighter is faster !!
