FWIW:
I run 14x6 w/21mm offset all round on mine using IAP lowered spings (1.25" ~ 1.5" drop over US spec stock) and things are showing to be getting close clearance wise.
It all fits, but I dunno how much more it could actually take width (on front due to fender clearance) or offset (interferance with inner wheel well on rear)
Some quick math on mine vs what you're looking at (and remembering that tires will increase widths by a bit on both inside and outside):
Mine:
6" /2 = 3" for center of wheel width + 21mm (.827") offset puts 3.827" from hub face the back edge of wheel
Clearance between tire and inner wheelwell at rear and lip of wheel opening at front: about the thickness pad to nail of my finger.
What you're looking at:
7" /2 = 3.5" for center of wheel width + 40mm (1.575") offset puts 5.075" from hub face to back edge of wheel
Clearance on the rear inner wheel wells I'm guessing won't be clearance at all. (you'd prolly be lucky to even get the wheel to sit flat on the hub)
Do
NOT take that as gospel. I'm not that great at math and my understanding of offset and such is not what one would call top of the line.
It's simply the numbers I came up with using the definitions of offset/backspace as I understand them. In other words, please wait for further confirmation from others who actually would know for sure.
I know there's folks out there using 7" wheels, but it's the offset that looks to be the killer in this instance.
If I'm wrong, feel free to tell me to piss off. I'll understand and just chalk it up to misuse or misunderstanding of how the numbers actually work and I'll keep my nose out of these tpye questions in the future.
