Rear Brake Compensator question
While replacing the rear rubber brake line, I noticed that the compensator was very corroded. After removing it and cleaning up the outsides with a wire wheel, I saw that one end was a plastic dome-like cap and that it wasn't sitting flush with the body due to corrosion. What exactly does this component do and is there a way to test it, before having to shell out $100+ for a new one?
Thanks!
Reed
1977 Spider (finally on the road!  )
