Old 04-20-2009, 04:57 AM
VA_Alfa's Avatar
Minimum Brake Rotor Thickness
I'm getting ready to replace brake pads on my 69 SV and I have a few questions from the more seasoned ATE brake people before I get started.
1. Is it standard practice to turn the rotors down at a brake pad replacement or is a complete disc replacement in my future?
2. What is the minimum brake disc thickness specification for a 69 SV?
Alex in VA
1969 Alfa Romeo 1750 Spider Veloce
Old 04-20-2009, 05:32 AM
TorW's Avatar
Slo-Mo Restorations, Inc.
1. Can't tell you what the standard practice is (not a shop, owns only one 105), but if the discs are straight and true (i.e. run-out within specs), I wouldn't turn them down.
2. 8.5 mm (.394") rear, 10 mm (.335") front, according to the DIASS manual
'99 166 3.0 (La Divina) // '72 Montreal (La Tempesta)
Old 04-20-2009, 04:45 PM
VA_Alfa's Avatar
Dumb question: What is the DIASS manual?
Alex in VA
Old 04-20-2009, 06:40 PM
papajam's Avatar
Trained Professional
DIASS is short for DIrezione ASSistenza Technica, the department within Alfa Romeo that, among other things, publishes technical, service and owners manuals.
Series 1 Euro 1750 GTV
Series 2 USA 1750 GTV
Series 3 Spider Veloce
Old 04-20-2009, 07:17 PM
There may be other opinions, but it isn't always necessary to turn rotors at every pad replacement. There are symptoms that indicate turning rotors is needed...oscillation under moderate/heavy braking for example. Turning usually takes off about .015/side, so you can measure the initial width and figure if there is enough meat to end up with the minimum acceptable rotor thickness. I don't do it just as a matter of course...It is good to knock the glaze off of the rotors if you don't turn them.
Jim will reply, and you can take whatever he says to the bank!
Jeff Lang
'85 GTV6 3L, '89 Milano Gold
'91 164S, '91 164L, '91 164L Parts Car
'89 Spider
'74 GTV project
Old 04-20-2009, 08:24 PM
VA_Alfa's Avatar
With the front end on jack stands and the wheels off, I checked the rotors this evening. They show very little wear, no scoring, no pitting, etc. Is there a shadetree mechanic method for knocking the glaze off the rotors without removing them from the vehicle?
Alex in VA
Old 04-21-2009, 03:50 AM
TorW's Avatar
I used 600 grit sanding paper on my front rotors to remove glazing. Just wrap the paper around a piece of flat wood and apply it lightly to the rotor while you turn it.
Old 04-30-2009, 04:52 PM
there should not be any glaze.... if so, might want to look at a better pad.
in any case, coarse sand paper should do the job.
andy
Old 04-30-2009, 05:26 PM
papajam's Avatar
Oh, poo. I forgot to post to this thread.
While sandpaper is commonly used to remove glaze, industry standard practice is to have a non-directional finish on the surface. This means making swirls on the surface of the rotor (caliper removal required for the inside surface). A non-direction finish reduces the pads' tendency to vibrate (squeal).
Old 04-30-2009, 06:15 PM
All rotors will be glazed-shiney, I use 120 grit and seat the pads hard...
Jeff Lang
'89 Spider
'74 GTV project
Old 04-30-2009, 06:59 PM
Tifosi's Avatar
Darth Slacker
Originally Posted by papajam View Post
This means making swirls on the surface of the rotor .....A non-direction finish reduces the pads' tendency to vibrate
:nod:
I've always been kinda fond of using a flexible disc sander head in a drill at slow speed to get that nice circular pattern when breaking glaze.
You gotta make sure to really clean things off well post deglazing or it'll just glaze up all the more quickly using the residual dust as a sorta base/primer coat, and if deglazing or turning has been done, the pads will need to be rebedded regardless of them being NIB replacements or putting older servicable ones back in.
If reusing older pads, it never hurts to break the glaze on them too, but with a finer grit paper (you wanna just skim off the topmost layer, not carve the things up and put grooves in them) done in a lapping fashion on a flat surface.
Darren
as hosted by
Greg Gordon's HI Performance Store
