Did the tyre fitters look up the GTA or the V6? The numbers are different, the latter numbers being for the 2.5 V6. That being said, neither the front nor rear camber is adjustable on a stock 156 GTA.
The 147, 156 and GT generally have a slight toe out in front and toe in at the rear, but I don't know the numbers or if the GTA have a different factory setup.
In any case, I'd go with the numbers in the owner's manual unless you have modified the suspension with huge rims and/or lowering.
'99 166 3.0 (La Divina) // '72 Montreal (La Tempesta)
