Rubber Front Spring Seats
Greetings,
I'm in process of refreshing the front suspension on my 72 GTV, I have a question regarding the rubber spring seats.
The upper spring seat (rubber and sheet metal insert) are in pretty good condition but the lower spring seat rubber is pretty well deformed and the sheet metal insert is corroded pretty well. If I obtain a good used set of upper seats and inserts can I use them on the lower end of the spring?
Thanks for the feedback...
Surfcity Alfa
72 GTV
