The first things I'd check is to ensure that there is no air in the system and the front wheels bearings and rear brake pad clearances are to spec.
If your 75 has a 20mm master cylinder, then a 22mm from another Alfa (Alfetta, GTV6) may solve the low pedal issue. If you already have a 22mm master, then a 23mm master from a Porsche (911 I think?) may work.
Series 1 Euro 1750 GTV
Series 2 USA 1750 GTV
Series 3 Spider Veloce
