it follows that if it is pressed onto the sway bar, that is a fixed position. This is the inner tube of the bushing. As it is a bushing, it follows that the inside tube is vulcanised to the outside steel tube via the rubber of the bushing. This is also a pressed in item. Same on the side of the spring pan. So: no!
4 Berlina's , one Scalino, and a Ferrari 308GTS to boot. Cool!
