you need to remove the brake calipers, then remove the hub assb. from the axle. then remove the 2 screw that hold it to the rotor( but some advice here, after you remove the 2 flat bladed screw from the rotor/hub, replace them with allen counter sunk screw, this will make any later repair much easyer)the tap the rotor off the bug, can be a tight fit. to re-instale reverse the instuctions, but on the rotor face( the part that sets behind the hub) use some anti seize, to keep the rust from forming and bonding the rotor to the hub....so easy...hard to type
