Old 02-17-2009, 07:24 AM
RAGs's Avatar
Alfisti
Brake question for a '67 Duetto
So I've started a grocery list for the pending resotration and I'm wondering about the brakes. The car originally did not have a booster in the system so I'm contemplating putting in one (just noticed a couple for sale on the BB). At the same time I misplaced the original master cylinder so now my options are really open. I already have the necessary ATE components ('newer and complete front spindles, 1750 axle shafts w/ backing plates and rear calipers).
Any suggestions on how best to proceed? Vacuum assisted or original? Thanks in advance.
Red '88 Milano Verde - When you just gotta to have 4 doors...
Black '86 GTV-6 - The one that got it started and needs to be re-started...
Yellow (soon to be) '67 Duetto - middle of delayed restoration...
--- Honorable Mention ---
Burgandy '94 Volvo 850 Turbo - Groceries ...
Emerald '90 VW Corrado - The Backup ...
Brown '71 C10 Stepside w/ a 350ci and 3 on the column - Just because ...
Old 02-17-2009, 03:50 PM
Check the Just Listed "Sticky" regarding Roundtails
It includes a section on brake options. If you add the booster, you should also change to a larger MC or the pedal may be too light. Mine has the larger ATE front brakes, but it's not in driveable condition now. I am adding the booster and larger MC, but for personal reasons. I would try it without and see if you like it. The booster reportedly takes some of the "feel" out of the pedal. You could always add the booster later if you don't like the required pressure (although you would then have to again change the MC. I think that the larger MC without the booster would result in a very hard pedal.
(2) 67 Duettos (currently being made into one decent driver)
97 Ford Taurus SHO (my daily driver)
99 Jeep Grand Cherokee (need something to haul the boat).
And a new Nero & tan 95 164 Quadafilorio as a second daily driver (at least in the summer!)
