Old 01-10-2009, 10:17 AM
fluid inside brake servo assist??
I have taken the brake master cylinder off of the servo assist unit and noticed fluid in the bottom of the servo case. Should this be there? I think not? The brakes function properly and I am not losing brake fluid from the reservoir so I am at a loss as to why about 3 oz of fluid is in the bottom of the case. Should I remove the fluid? This is on a '71 spider 1750.
Getting older and going older!
  • '67 Alfa Duetto 1600
  • '71 Alfa Spider 1750
  • '79 Alfa Euro Spider 2000
Old 01-10-2009, 10:30 AM
papajam's Avatar
Trained Professional
No, the fluid in the servo should not be there. It can be removed using a turkey baster or similar.
The source of the fluid in the servo is (or was) a leaking rear seal in the brake master cylinder.
Series 1 Euro 1750 GTV
Series 2 USA 1750 GTV
Series 3 Spider Veloce
Old 01-10-2009, 10:38 AM
Thank you Papajam! Common sense told me to that was the problem, but I find it always best to solicite the factual anser to my problems from experienced and knowledgable persons like you. Thanks again.
Capt Jim
