01-10-2009, 02:57 AM
Brake Line JigSaw Puzzle!!
Hello part of my 1750 ground up restoration has now lead me to do renew all the brake line plumbing.
Series 1 1750 with a single booster brake system.
I have had all the lines made with appropriate fittings and lengths based on the exsiting lines which were in bad shape.
The new lines have not been bent into shape and are in straight lengths. I am looking at the old lines and trying to make head or tail where they should go...also I am not confident that the old ones are in the correct shapes as they were originally "ripped" out so I am not sure how and where to bend the new ones into the appropriate shape...
Does anyone have any advice on the best approach for this, I dont have bending tools ? Does anyone have any guides or pictures of these lines etc that may help me here?
01-10-2009, 08:20 AM
If you don't have any pictures or can't locate any pictures, the parts book should help, some.
I'd start by mounting up the booster, reservoir, pedal box, brake MC, Clutch MC, etc. Using this page from the parts book should help you get started figuring out where the lines go. They will only go in one way. If they are bent out of original shape, you could try and make them fit. Be careful not to bend them too many times as they could crack. Them you can use them as templates to bend the new lines.
Most people that I know will use hanger wire to form templates. Hanger wire is easy to bend and very cheap to replace.
01-10-2009, 06:55 PM
thx mate! the hanger wire idea is brilliant....should I look at investing in a pipe bending tool of any sought when I am ready to bend the good stuff?
01-10-2009, 09:08 PM
...in the Garage...
another option would be to use copper tubing of the same size to create the template part...this will allow you to make the straight lengths between the bends even closer to the final part....and of course copper is super easy to bend.
01-11-2009, 09:50 AM
I don't think it's necessary to invest in a special tool. If you are uncertain about making the bends, buy some some generic straight stock brake lines and have a go with those. That way, you can get a really good feel of how it's going to be with the real stuff. You just want to be careful and not keep bending the same curve back and forth. Bend a little at a time to get the proper curve. Don't try to bend the curve all in one go.
01-18-2009, 09:30 PM
guys tyhis has been most helpful....question does anyone have aphoto of how the piping is connected to the brake master cylinder. I do not have the Ate type master cylinder, I have the bonaldi type and not sure which is the inlet or the outlet of how to connect, ist such a tight angle!!
01-19-2009, 05:34 PM
Trained Professional
Rule of thumb is that the inlet is in the vicinity of the front (pressure side) of the piston while the piston is at rest. The outlet is toward the end of the piston's travel when it's pushed.
In other words, the inlet on your single circuit M/C is the fitting closer to the pushrod end; the outlet is closer to the sealed end.
Series 1 Euro 1750 GTV
Series 2 USA 1750 GTV
Series 3 Spider Veloce
01-25-2009, 07:16 PM
OK guys...I am trying to find illustrations and photos of examples of how to best run the brake lines and clutch line reservoir in the engine bay....can anyone help?
...ideally for rhd single circuit configuration...but LHD is ok as well i will get the idea....
.....this community is a wonderful reasource and I hope to give back by completing my thread with the results of everyone's advice....
01-28-2009, 07:25 PM
...in the Garage...
Frank,
last night I proceeded to re-install my old brake lines and M/C so as to take some photos for you. However I then realised that the steering box, boosters, clutch and pedal box should also be in position since the lines need to wrap around these items. I won't be able to get all these installed for at least a couple of more weeks....if you can wait till then I'll shoot some photo's and send them to you.
01-28-2009, 07:52 PM
These have been previously posted on the BB of the Giulia Wagon in Melbourne owned by Jock.
Should be the same route as yours I would think. I have a tonne of picks of my previous Sprint GT with the engine out and brake lines in place. Just dont know which disc, computer they are on sorry.
Derek Entesano
1966 Giulia Super (Driver) AR 721136 Biancospino
1967 GT Veloce (Resto) AR 299772 Rosso
www.giuliasuper.com.au
01-28-2009, 09:59 PM
Thx..!! those images are fantastic... It has clarified a great deal for me....I did notice that you have an extra bracket fixed to your engine bay which holds your lines much neater...I have attached the .pdf of what I am describing....I was wondering if there are line brackets that I could fix to my engine bay to do the same thing? Do you have any syggestions...?
I am also interested in seeing how your piping is laid out to the clutch and brake mastercylinders if you have them...?
01-29-2009, 05:37 AM
...in the Garage...
Those photos show the routing to be significantly different than for a RH drive GT....so any photos I would have taken would not have been of much use to you...even if you were to symmetry the installation. As for the bracket, most are not much more than flat bent-up pieces of sheet metal which your body guy should be able to tack weld on quite easily.
02-03-2009, 08:04 AM
I want to purchase brake line clips which I can fasten to the engine bay to neaten up my piping. I am looking for multiple pipe allocations per clip...anyone have any ideas where I can find something like this?
09-14-2009, 10:25 AM
Originally Posted by 1750GT
Frank,
Have you managed to install and photograph these by any chance?
I am looking for some brake line fixing brackets as well...an ideas?
I have since got new lines made, and they come coated these days..the annoying thing is as you work with these, the coating starts to scratch and crack.. I am considering getting some paitn stripper and stripping off this coating...
Has anyone had nay experience with the new brake line coatings and how to remove it??
Reason: correct grammar
09-14-2009, 12:51 PM
...in the Garage...
At the time I was going to, but instead marched on with the rust repairs on the body. Again, my car is a dual booster US car and I don't imagine the routing would be applicable to your RH driving car single booster car....would it?
