Old 07-05-2008, 02:27 PM
Geo4 Geo4 is offline
Send a message via AIM to Geo4
Wet passenger feet
My '89 Spider's passenger footwell fills up with water, sometimes, after a heavy rain or a vigorous washing. I've noticed 2 peculiar things when this happens:
1. The outside of the AC housing under the dash is all wet.
2. The Coco Mat has a reddish tint to it.
I recharged my AC a few years ago and included a Freeze 12 leak indicator dye, which I believe is the cause of the red.
There's just so much stuff jammed under the passenger side dash of the AC-equipped car that I don't know where to begin to look. I'm assuming that the water is coming in through the vent near the windshield, which is why it's only wet sometimes (depending on the direction of the rain/hose spray).
I've checked the drain hose for the AC and it's nice and clear - a blocked AC drain wouldn't explain why the outside of the housing is wet.
Any ideas to save me the painful process of getting up under the dash without a plan will be greatly appreciated.
Thanks.
Geo.
Monroe, GA
89 Spider Graduate
60 Triumph TR3
73 Triumph GT6 Mk3
03 Mazda MPV dog hauler
91 Nissan King Cab parts hauler
Old 07-05-2008, 02:45 PM
Zunige's Avatar
Zunige Zunige is offline
In the Spiders' nest...
There is a cowl drain hose on either side of the car. You can see them from inside the passenger compartment. If the one on passenger side is torn (not unusual after so many years), then water will leak into the car. Replacement hoses are available from the usual suppliers...
You may also try a search, as I'm positive this subject has been covered before, and I also recall some pictures by BB member ghnl...
Best regards,
Enrique
Spider 74, 84 & 87
164 93L & 95Q
Milano 88 Verde
Old 07-05-2008, 03:42 PM
Vintre's Avatar
Vintre Vintre is offline
I had the same problem with my S4.
My drain cowl was cracked.
If you pull your glove compartment box you will see it clearly.
Good luck.
1991 Spider Veloce - Red on Tan - Rossa Bionda (for now)
1987 Spider Quadrifoglio - Red on Grey - Rossa
Old 07-05-2008, 04:48 PM
bianchi1 bianchi1 is offline
i have noticed , on rainy days water will creap aroung the lower rubber windsheild , on the corners, and get my feet wet.
don't follow me,i'am lost
Old 07-05-2008, 05:09 PM
Zunige's Avatar
That means that there is no glue (in the corners) between the rubber windshield gasket and the windshield...
Best regards,
Enrique
Spider 74, 84 & 87
164 93L & 95Q
Milano 88 Verde
Old 07-05-2008, 05:11 PM
glue..no need for 'stinking glue' i like 'duct tape..
Old 07-05-2008, 09:25 PM
radamm radamm is online now
Fast in Black!
Ooh Pancho, we don't need no stinki...........
__________
Rick
69 850 Spider
81 Spider Veloce
