Clutch noise?
I'm stumped. My 69 spider was mechanically rebuilt by an old master and then sat for nearly 8 years before I bought it, installed the interior, cosmetics, redid brakes, etc. I pr flushed all fluids and rechecked all mechanical specs, reset cams, all timing, etc. It has a euro style Weber conversion with proper manifold and intake box.
This spring the car starts immediately, idles right where it should and drives beautifully.
However, once fully up to temp, at idle to about 1400 rpm, I have a low frequency rumble, almost grumble, that ties to engine speed. (This is not present at first when the drivetrain is cold.) When I rev, the rumble goes away. The clutch works well but engages near the end of the stroke.
As soon as I engage the clutch, the sound is gone as well.
Everything else works as it should. The starter engages and disengages properly...no loose parts I can locate.
I very much appreciate your suggestions.
Thank you.
GMack
69 Spider
74 GTV
