  #16 (permalink)
Old 06-29-2008, 10:10 PM
sicduc sicduc is offline
He bought 3 cars over there and he selling all of them to pay for his daughters wedding atleast thats what i was told by his son-inlaw. He handled the deal.. I'll post some pictures when i get a chance..
  #17 (permalink)
Old 06-29-2008, 10:17 PM
Tifosi's Avatar
Tifosi Tifosi is online now
Slacker
That would be hip.
OK, back to it:
When you first turn the key from off to run, do you hear the fuel pump(s) buzz/hum for half a second or so? (it'll be just a quick 'bzzzt', so you may have to turn the key off and on a few times to catch it)
Check that while you're checking for fire I guess.
Do you have a multimeter?
If so, check the battery voltage, then check it at the battery terminals while cranking. If it drops below 10.5 volts, you're not going to get it to go anyway. (this is going on the off chance that mabe your alternator or regulator decided to take a crap during the trip home. Regardless, you need to check the voltage anyway, otherwise you can crank for days and still not get it to fire if the volts are at or below that 10.5V threashold)
Darren
'84 manufacture - '85 MY Spider Graduate
  #18 (permalink)
Old 07-10-2008, 07:38 PM
It was the crank position sensor.. What ever its fixed.. Thanks for all your help..
  #19 (permalink)
Old 07-10-2008, 10:54 PM
VIRGIL4206 VIRGIL4206 is offline
where is the crank position sensor? if you don't mind...
  #20 (permalink)
Old 07-11-2008, 08:44 AM
I was told its on the bell housing of the tranny..
  #21 (permalink)
Old 07-11-2008, 11:34 AM
Tifosi's Avatar
Slacker
Yes, the ones listed as 'black' and 'gray'
Darren
  #22 (permalink)
Old 07-11-2008, 01:19 PM
ghnl ghnl is online now
Originally Posted by Tifosi View Post
Yes, the ones listed as 'black' and 'gray'...
Note that the 'black' & the 'grey' connections are not at the bellhousing the way that sketch makes it appear. If you follow the sensor's cable up to where they plug into the harness, you'll find a black & a grey connector. The sensors themselves are identical but they must be connected to the harness correctly. The harness connectors are in the vicinity of the windscreen washer reservoir.
- Eric
don't read this!
- 1984 Spider Veloce -
~ North Carolina, USA ~
