Old 06-25-2008, 07:08 PM
Antiacus Antiacus is offline
I've hatched a plan to get to my starter solenoid
I started off deciding i would pull the intake plenum off my 82 and access things that way. After pulling most of the hoses I went for the bracket underneath. After dropping my wrench for the 6th time, i decided to pull the washer fluid reservoir and unscrew the solenoid from the starter.
Reservoir came off lickedy split. Disconnected battery after a neato spark-show and disconnected the power. Then i got my stubby standard screwdriver (what kind of sick commie uses recessed flathead screws in that?) and wiggled my hand through the various tubes, gadgets, gizmos etc and managed to match the driver to the screw by closing my eyes and using the force.
I then began to apply counterclockwise pressure. After 10 minutes of slipping, grunting, and cursing the sadist who decided to use standard screws on that I gave up.
So now i'm on to plan C!
I'll remove the starter, turn it pointing down, and access the screws to get the solenoid off without having to pull the starter out of the impossible coccoon of wires, tubing, rods, brackets & other parts in which it lives. I'll then replace the solenoid, put the new one back into the starter, and reinstall.
Unless someone else has a better idea
-Antiacus
Christopher Anderson
82 Spider
"soon" to be gtv-6 owner
Old 06-25-2008, 07:49 PM
jclark's Avatar
jclark jclark is offline
Pulling the starter up through where the Washer fluid was, is the right way. It *will* come out through there.
Removing the Intake Plenum can make it easier ( albeit more time consuming ), but if there's stuff in there you wanna muck with, then head on!
jeff
1982 Spider Veloce
1999 BMW R1100S
Old 06-25-2008, 08:33 PM
Thanks man. I'll give it a go.
-Antiacus
82 Spider
