Old 06-23-2008, 08:06 PM
Need4speed's Avatar
Need4speed Need4speed is offline
Sluggish starting....advice please
I had my '91 in for top and upholstery change and coincidentally, after I got it back it starts with slower, weaker cranks. Battery indicator show strong when running and on start-up.
New Optima battery last year.
New ignition switch last June 06
Rebuilt starter last October.
Rewired starter system last October too.
Since then strong quick cranks.
It still starts now but cranks are weaker (3-5 turns), and feels like if taxed, may not have enough to start.
Connections, relay loose?
1991 Alfa Spider, 1980 MGB LE, Triumph Spitfire, Miata,
"I feel the need!"
Old 06-23-2008, 08:17 PM
ghnl ghnl is offline
I'm guessing here but it is likely that the doors were open for a long while during the top installation & upholstry work - leaving the interior lights on & partially draining the battery.
Have you tried cleaning the battery cable connections and the ground strap's connection to the body? And the + cable's connection to the starter motor? (do that while the battery is disconnected)
- - Eric
don't read this
~ 1984 Spider Veloce ~
Mebane, North Carolina
Old 06-23-2008, 10:14 PM
Jack Sprat's Avatar
Jack Sprat Jack Sprat is offline
Makes sense, take her for a good run.
92 Alfa Spider,
Keep it lean!
