#16 (permalink)
Old 06-24-2008, 01:57 PM
dghii dghii is offline
Nice car!
Don't fret, the alfa was designed to strand you with no prior sign of impending doom.
You get use to it after a while.
I didn't see an intertia switch on the firewall but that is another culprit of "it was running fine but now it won't run at all'
Your ignition switch has a wire to the starter and one to the fuse box. Do your gauges work while trying to start the car?
The ignition switch is easy to bypass if you need to test it.
Don - 1984 Spider Veloce
  #17 (permalink)
Old 06-28-2008, 05:19 AM
preconnect's Avatar
preconnect preconnect is offline
question - does this scenario make sense for my no-go situation?
During our 2nd cruise as Spider owners, my wife was fiddling with buttons and switches. I think she put the a/c on (knob at bottom of console numbered and turns) and the green fan switch. Could this have over loaded the alternator and put a draw on the battery thus shutting down the ecu??? All else has checked out ok so far in terms of l-jet/spark/fuel.
thanks
  #18 (permalink)
Old 06-28-2008, 06:11 AM
Zunige's Avatar
Zunige Zunige is offline
In the Spiders' nest...
thanks
No. Turning the A/C and the fan (green switch) for the heater/defrost at the same time and running like that will not hurt anything. We've done it many times, especially on a muggy day when the skies open up and the windshield has fogged up...
Best regards,
Enrique
Spider 74, 84 & 87
164 93L & 95Q
Milano 88 Verde
  #19 (permalink)
Old 06-28-2008, 06:27 AM
mmolto's Avatar
mmolto mmolto is offline
Congrat on your purchase! The quads are beautiful and yours looks great. I hope your able to get your issues sorted out.
I find there is always something you either need to do or want to do with these cars.... for me it's all part of the ownership experience.
Enjoy
1991 Alfa Romeo Spider Veloce - Silver- "Halle"
1991 Alfa Romeo Spider Veloce - White -"Name TBD"
  #20 (permalink)
Old 06-28-2008, 11:19 AM
shadowburn shadowburn is offline
thanks
As Enrique said previously, no.
Remember though, with the ventilation system in the Quads, the A/C and heat/defrost vent airflow are two separate entities. Your cold A/C air flows out the center dash and side vents only while the heat/defrost airflow comes out the top and under dash vents. The switch above the the levers control the fan for your heat and defrosting with one of the levers splitting the airflow between the top and underdash vents. The A/C control knobs have one for the A/C temp and a three speed control for the A/C fan only.
This may sound dumb, but have you actually checked the ground connection by the battery and or tried to just jumpstart your Quad? I know you said you took it out for a second drive and then it stalled and you couldn't get it started again, but as was previously posted the computer needs a certain voltage to wake up. The starter will sound nice and strong, but it won't start.
Either way, cleaning the ground and charging up the battery should be done. Trying to start it for the past few days without any luck, has probably drained the battery enough so it won't start anyway and you won't know if anything you may have corrected or connected properly under hood has helped with your situation.
Good luck and have fun! Cuz you're already getting to know your Quad's little quirks and personality.
'87 Series 3
  #21 (permalink)
Old 06-29-2008, 09:26 PM
i_87spiderquad i_87spiderquad is offline
I have a 87 spider quad and it too would not run after sitting in the parking lot for a few hours on a hot day. It drove fine in the morning (weather was in the 60-70s). In the afternoon (weather now in the 90s) it started fine and I pulled out of the parking lot and about 100 yards later engine idled very rough. I pulled over to the side and it died. I tried starting it again, but it would only turn over and idle very rough then die. I had it towed to my mechanic that afternoon. The next morning (weather once again in the 60-70s) the mechanic said it started and ran just fine. After warming it up for a while he said that the problem was the fuel pump.
  #22 (permalink)
Old 06-30-2008, 10:44 AM
preconnect's Avatar
The verdict is in, my Spider needs a new fuel pump (external not the in-tank pump). I'm going to change the filter as well while I'm at it. I had the mechanic give it the once over and there are a few other "things" she needs to pass Pennsylvania State inspection. So it will be a busy summer under my Spider. Thanks to all for the valuable info and advice. I'm sure to be posting more soon.
Thanks again.
Mike Hochhaus
1986 Spider Quad
  #23 (permalink)
Old 07-29-2008, 07:31 AM
preconnect's Avatar
Update
She's back!!!
Well after a good long month I have the Spider back home. She ran well yesterday, but still has some electrical issues to resolve. I'm tackling them in another post. I just thought I would share some pics of her in her new home. I'll share some more as my work progresses. I do have one question. We're the 1986 Spiders clear-coated after paint? I used some GRIOTs Machine polish on a small spot last night with GREAT results but wasn't sure I saw any silver residue on the rag (I'm told evidence the pain job was single stage).
Thanks to all for the invaluable help so far!!!
Mike Hochhaus
1986 Spider Quad
  #24 (permalink)
Old 07-29-2008, 08:42 AM
90Quad's Avatar
90Quad 90Quad is offline
Yes they were clear coated. Yours looks to have been at least partially repainted, but it almost certainly still has a clear coat.
Seats look great. How many miles on the car?
90 Quad RIP (But it's parts live on.)
  #25 (permalink)
Old 07-29-2008, 08:55 AM
Actually, I don't believe they were clear coated. My 87 still with original paint is not clear coated. If I ever decide to repaint, my preference would be for no clear coat as well. Depends on what may be available in future in the way of "legal" paint. I also like the single stage because if you get a scratch or ding you can touch up with color and just blend it in. If my paint gets oxidized and hazy, I just polish it gently and it shines right up.
'87 Series 3
  #26 (permalink)
Old 07-29-2008, 09:12 AM
preconnect's Avatar
90Quad the car has 105K on the ODO. Shadowburn thanks for the response. Anyway to definitively tell one way or the other. I know enough not to try to polish or "blend" a clear coat paint job.
Mike Hochhaus
1986 Spider Quad
  #27 (permalink)
Old 07-29-2008, 09:47 AM
90Quad's Avatar
The paint info was originally on a sticker on the underside of the trunk lid. Here is the one from a 90 Quad. All silver Quads were the same paint (unless repainted.) Someone on here can probably confirm this was a two stage paint (I believe that is what the "2 coats" referes to.) If not, a paint supplier of Glasurit can.
You can polish clear, but you always want to make sure you are using the proper product. You want to avoid sanding unless you really know what you're doing.
You are right on the blending of paint part. Every time a paint shop said oh we'll paint the back and blend through the door, they ended up painting again and doing the whole door.
