Old 06-21-2008, 05:48 PM
Arachnoid86's Avatar
Arachnoid86 Arachnoid86 is offline
Throttle Linkage Pic or Diagram.
Hey Y'all! Does anyone have or can point me to a pic or diagram of how the throttle linkage rods are connected from the firewall to the throttle position sensor for a 2L Bosch 86 Spider Veloce? And one other question, where does the negative (black) battery cable connect under the hood??
Thanks for your time...
[FONT="Palatino Linotype"][SIZE="4"]Arachnoid86[/SIZE][/FONT]
Old 06-21-2008, 07:48 PM
Tifosi's Avatar
Tifosi Tifosi is offline
Slacker
There's a pic around here somewhere (I think ghnl posted it if you wanna search) but basically it's the long adjustable rod from the ball that the firewall to the throttle bellcrank under the plenum, then the short rod from the bellcrank to the TPS.
It doesn't.
The negative is connected back by the battery via a bolt directly to the chassis.
Darren
as hosted by
Old 06-21-2008, 08:53 PM
ghnl ghnl is offline
Try these threads: 1987 Spider Throttle
Resisting Gas Pedal
Stuck accelerator
And, to get technical, your Spider has a Throttle Position Switch, not Sensor...
As Tifosi says, the negative battery cable attaches to the trunk floor near the battery. There is (or is supposed to be) a ground strap from the bellhousing to the body in the transmission tunnel.
- - Eric
don't read this
~ 1984 Spider Veloce ~
Mebane, North Carolina
Old 06-21-2008, 09:01 PM
Big Black Cable
Thanks for the quick response Tifosi. From your advice, I have successfully installed the throttle linkage. In reference to my second question about the battery cable, I've got a thick black cable, looks about like a 10 gauge or thicker that runs from the truck area along the bottom of the passenger side of the car then it routes up by the bell housing and then up along the firewall and reaches to just under the plenum. Is this supposed to connect to the starter solenoid main?
Thanks again for your time.
Oh yea, the reason I had taken the throttle linkage out is because I was having issues with those sticky firewall rubber bushings for the accelerator rod feed through. By un-welding then re-welding an end on that firewall rod I was able to replace those rubber bushings with two skate board wheel bearings I special order for the diameter of that rod. Don't know if they work yet but damn the action is smooth right now......
Last edited by Arachnoid86; 06-21-2008 at 09:09 PM. Reason: ghnl's reply sparked a thought!
Old 06-22-2008, 12:43 AM
Tifosi's Avatar
Slacker
That's the +, and yes, it connects to the large terminal on the starter solinoid.
Darren
as hosted by
Old 06-23-2008, 08:44 PM
Mucho Thanks Tifosi, I was hoping I could get one last question answered and you seem to have a great intimate knowledge of the Alfa autos. I've got a red with a black stripe wire with a female spade connector on the end that originates from the passenger side firewall and extends to about half way down the block. Any ideas where this might connect?
Old 06-23-2008, 08:58 PM
Tifosi's Avatar
Slacker
If I'm not mistaken, it goes on the blade on the solinoid. (you might want to wait for further confirmation of that though, as I could be totally wrong and it's the oil sender unit wire)
Darren
as hosted by
Old 06-23-2008, 11:07 PM
Thanks again for the quick reply Tifosi. I found the Starter Solenoid ignition signal wire by measuring the voltage during the turning of the key. But I think you're onto something about the oil sending unit though. I think I have only two female spade connectors that are not in a plastic connector shell on that side of the engine. I'm going to try and find the oil sending unit to make sure it either has a wire on it or needs this one. This one did measure about 8 - 9 volts as soon as the ignition was turned to the on position. Thanks for sharing your knowledge.
Old 06-23-2008, 11:59 PM
Tifosi's Avatar
Slacker
Aha!
According to the 'P4.pdf' attachment in this post by papajam, one of the wires that goes to the oil pressure gauge is indeed red with a black trace. (I realize the schematic is for a late S3 w/monopod, but that bit of harness is almost surely the same on the dual pod)
Darren
as hosted by
Old 06-24-2008, 06:23 AM
papajam's Avatar
papajam papajam is offline
with the Librarian
Originally Posted by Tifosi View Post
...one of the wires that goes to the oil pressure gauge is indeed red with a black trace.
Alfa has used a red/black stripe wire for the oil pressure gauge sender for decades.
Series 1 Euro 1750 GTV
Series 2 US 1750 GTV
Series 3 Spider Veloce
