Fuel problem?
OK, I'm getting to wit's end.
I have a 90 spider with the Motronic system. I've had on-again, off-again problems with it since I bought it two years ago. However, since I don't have a good mechanic in the area -- I live in Jefferson City, Mo. -- I've done most of the work on it myself.
On my first trip in the car -- St. Louis and back -- I blew the water pump. Fixed.
Recently, I've been having problems getting it to start. I first went after the electrical/ignition side of the house. I replaced the plugs/wires/distributor and ordered a Hi-performance hose set to eliminate any problems with false air. Eventually I tracked the no-start to the fuse for the fuel pump (a $9 solution.) At that point I was at about $500.
The car ran great for a day. Next time I tried to start it, the starter was fried. I replaced the starter, and while the engine now cranks, it does not start. I recharged the battery and get 12.4v at the battery. I also replaced the fuel pump fuse again with a spare I had sitting around. Nothing.
I am not an expert. I'm also unclear on how to check the fuel system to make sure that it's not a filter or pump that's my problem. I do have spark (ckecked with a light) so I'm thinking that it's a fuel issue.
Please, please recommend where I should look next. I'd prefer not to have to spend tons more to make her roll. But, I have to admit, my wife's calls for a trade to a Miata are starting to be hard to rebut.
Thoughts? (Outside of a Miata.)
