Old 06-08-2008, 07:41 AM
bigpapajoe's Avatar
bigpapajoe bigpapajoe is offline
name this part!
found it inside the passenger door panel at the bottom...my dad can add more info.
Joe Papa
Clearwater, FL
'87 spider veloce: All dinged up from college parking lots :
Old 06-08-2008, 07:47 AM
RayKiszely's Avatar
RayKiszely RayKiszely is offline
And the answer is ........
Joe:
I'm not certain of the name, but I believe it is the small rubber stop/clip that goes on the bottom of the window glass to keep it from making a hard glass on steel contact when the window travels to the bottom of the track.
Ray
Ray Kiszely'84 Spider Veloce
Old 06-08-2008, 08:00 AM
Wow Ray, you hit another one...LOL!! Thanks!I believe your diagnosis is correct. I guess this rubber must /should fit v snugly on the glass, or it will fall off v easily. Maybe I should add a dab of glue to it.
Old 06-08-2008, 08:07 AM
RayKiszely's Avatar
Glue will do it.
A little rubber cement will do the trick, while you are in there make sure you lube the cable a little.
Ray
Old 06-08-2008, 11:18 AM
Got it, Ray. Yup, lubed with heavy 30w oil....now for the rubber cement.......
