Richard Dawson:
Let's look up at the board where we polled 100 different people and show us 'what model year'!
Centerline outer wheel bearing
Centerline inner wheel bearing
Seals I couldn't find right off as I figured it wasn't my job to look too awful hard, but they have them. Just call and ask. IAP has the stuff too. Try harder when looking through the online catalogs, or call and ask.
In fact if you order by phone, they'll likely ask YOU if you want/need a set rather than you asking if they have them.
The inner seal has to come out to get the inner bearing out.
One way is to remove the hub and knock it out from the front with a drift as you surmised.
You do have instructions on how to properly re-tighten the hub nut don't you? (it definitely ain't done like any 'merican car you nmay have ever done, and in fact using the same method on the Alfa can potentially destroy a new set of bearings right quick)
