06-05-2008, 09:41 PM
Door handles/locks/panels
1981 Spider 2000 USA - It's SpiderWebb cuz' Webb's my last name.
06-17-2008, 05:44 PM
Engine Mount Replacement
Here is one to replace Engine Mounts. Your not an Alfisti till you've done this one!
http://www.alfabb.com/bb/forums/spid...t-dummies.html
1991 Spider Veloce - Red on Tan - Rossa Bionda
1987 Spider Quadrifoglio - Red on Grey - Rossa - Sold
06-17-2008, 05:47 PM
Door Limit Strap Installation
Here is one for Door Limit Strap Installation. Very good one, especially since it's mine!
http://www.alfabb.com/bb/forums/spid...tallation.html
06-20-2008, 08:20 AM
Darth Slacker
Setting up an emergency release cable for when the hood release cable fails:
Hood release failure
(w/pix + pic of emergency cable for trunk release)
Opening the trunk after the release cable fails:
Help, I can't get into the trunk
(w/pix)
Installing an emergency trunk release cable:
Clickme
(w/pix)
06-20-2008, 06:00 PM
Darth Slacker
Post from ghnl that has a schematic of the clutch master cylinder rod adjustment along with links to the upgraded clutch pivot arm and how to R&R it:
84 Spider, clutch pedal height adjustment?
Post from me with schematic of how far the slave cylinder should travel as measured at the end of the clutch fork:
How much should clutch slave rod move?
Reason: added slave cylinder link
06-22-2008, 10:12 PM
Darth Slacker
Pictures and description of the not often discussed (or even known about in some cases) thermostat bypass valve that's located in the hose that goes from the bottom of the manifold at the T-stat end down to the water pump.
Off-site link to a description with schematics of the purpose and function.
Orientation is with the small hole shown in 2nd pic toward the T-stat.
Pics of the actual valve itself as supplied by BattleBug a couple years back:
More pix added as supplied by Pat Garrett
Reason: to add more pix
06-27-2008, 01:16 PM
Darth Slacker
Pic showing the common location of the warning buzzers, or chimes if you prefer, for the seatbelt and 'key in ignition with door ajar'.
They are the two small white or gray rectangular boxes on the side of the steering column support plate.
Sorry, I don't know who originally posted the pic, but thank you for sharing just the same.
07-06-2008, 02:49 PM
Darth Slacker
07-14-2008, 05:54 AM
Killer rabbit
Steering wheel removal
How about some advice on how to get rid of those awfully-stuck steering wheels - without destroying half the car in the process?
(An Alfetta thread, but the problem is universal.)
Currently: '74 Spider Junior 1600, '77 Alfetta GTV 2000, '79 Alfetta GTV 2000, '79 Sei 2.5 V6, '80 Sei 2.5 V6
07-23-2008, 01:32 PM
Darth Slacker
A big long thread to go through with all sorts of thoughts and ideas on engine cooling fans.
Is switching to an electric fan worth it?
08-06-2008, 01:23 PM
Darth Slacker
Timken front wheel and rear axle bearing p#'s as provided by John Davison in this post.
SKF bearing kits for same as provided by CarlosSpider in this post
08-12-2008, 10:25 AM
Fuse Box Upgrade
Here is a link to a thread in which the ever knowledgeable Tifosi describes how he updated his fuse box from the old VW bullet style to modern minifuse:
http://www.alfabb.com/bb/forums/spid...project-8.html
Scroll down to the bottom of Page 8 and continue on Page 9. Great stuff, as ever.
Andy
85 Spider -built in Sept. 84
