Old 05-28-2008, 10:14 PM
Need4speed's Avatar
Need4speed Need4speed is offline
Ticking sound.....
On acceleration, especially in 1st and 2nd gears, sometimes in 3rd. Sounds like my tappets/lifters did not my Miata when the oil was thin/tired. Right behind the steering wheel.
Ideas? Exhaust manifold?
If its the tappets/lifters, how do you fix, just adjust/tighten 'em, or replace?
Thanks.
1991 Alfa Spider, 1980 MGB LE, Triumph Spitfire, Miata,
"I feel the need!"
Old 05-28-2008, 10:44 PM
Gubi's Avatar
Gubi Gubi is online now
I'd start by checking the exhaust header nuts for tightness and the tubes for cracks.
1991 Spider
1987 Milano Gold
Old 05-28-2008, 11:53 PM
Tifosi's Avatar
Tifosi Tifosi is offline
Slacker
Good call.
Start at #4 rather than #1 onaconna it seems to be the one that likes to loosen up first. (you can also look for soot or dirty deposits on the side of the block under the manifold to get an idea if/where blowby may be occuring)
Darren
as hosted by
Old 05-28-2008, 11:58 PM
garwood1's Avatar
garwood1 garwood1 is offline
A bit off the wall, but as you said you heard the noise behind the steering wheel, could it be speedo cable clicking ? Does the sound rise in tempo with engine speed (RPM's), or road speed ?
Old 05-29-2008, 12:22 AM
Tifosi's Avatar
Slacker
Wow, everyone is on the ball tonight!
What the hell man? LOL
Darren
as hosted by
Old 05-29-2008, 08:09 AM
Need4speed's Avatar
It builds on acceleration in the lower gears. It mat be a crack on the downpipe(s) behind the manifold..........I scraped the bottom underestimating the slope of exit in a gas station last week
Tom, will check m/nuts too. Thanks.
"I feel the need!"
Old 05-29-2008, 01:37 PM
Need4speed's Avatar
Was the exhaust manifold bolts
"I feel the need!"
Old 05-29-2008, 04:02 PM
Gubi's Avatar
Well there you go, Keith.
Are the nuts brass? If not they're probably going to loosen up again.
1991 Spider
1987 Milano Gold
Old 05-29-2008, 04:29 PM
Need4speed's Avatar
Cripes! loose nuts sinks ships!
"I feel the need!"
Old 05-29-2008, 04:35 PM
Tifosi's Avatar
Slacker
And loose lips harbor crabs
Darren
as hosted by
Old 05-29-2008, 08:22 PM
Need4speed's Avatar
crazy glue
"I feel the need!"
Old 05-30-2008, 05:16 AM
Alfacliff Alfacliff is offline
stuv904 is a spammer, spam reported
cliff
Old 05-31-2008, 02:03 AM
flaatr's Avatar
flaatr flaatr is offline
I think I have the same problem... what should they be torqued to?
-Raffi
-1974 Alfa Romeo Spider (still working on it)
-1980 Volkswagen Scirocco (Bone stock & original, 51K miles...)
-1987 Volkswagen Scirocco 16V (2.0L, Nothing stock or original)
-2003 Volkswagen Jetta TDI (Saves me money for the above)
  #14 (permalink)
Old 05-31-2008, 06:49 AM
Tifosi's Avatar
Slacker
As they are the same sized studs as the intake manifold, I'd hazard the torque would be the same: 12ft/lbs (the concern is more about not ripping the studs out of the head, rather than having something fall off)
However the number really doesn't matter as you'll never get a socket in there to actually use a torque wrench, so 'tight but not reefed' (as in don't lean on the things) is the more realistic tension to be applied.
Darren
as hosted by
  #15 (permalink)
Old 05-31-2008, 09:16 AM
flaatr's Avatar
Capito!
Grazie
-Raffi
