Old 05-26-2008, 10:41 PM
Carro-Kann's Avatar
Carro-Kann Carro-Kann is offline
Stock Engine Compression Readings
Hi to everybody. Can you tell me what the normal stock engine compression readings should be for a 1983 Spider is or direct me to a link? I have the service manual from International Auto Parts, and the Alfa Bible book (and the Internet) but I could not find normal engine compression readings for my stock motor. I performed compression readings on all for cylinders at normal temperature 68 degrees with all plugs removed. Average readings were low; cylinder 1 =100PSI 2 =110 PSI, 3 =112 PSI, 4 =110 PSI. I added a cap full of oil in and let it settle for a couple of minutes. Readings barely increased. Cranking power was on the slower side. I was reading one of the books tonight and it said to warm engine up then perform compression test. I will try again next week with the motor warmed up but even cold should the readings be this low? The car runs good BUT I question the horses I’m getting from the motor. From driving the car am I correct by saying “You have to work the gears?” meaning you really have the rev the motor then shift to get optimum horsepower? Thanks for your time. Sincerely Bill.
Old 05-27-2008, 02:15 AM
Tifosi's Avatar
Tifosi Tifosi is offline
Slacker
Those numbers appear more than a bit low. Did you make sure the throttle was WFO while doing the test?
The tweak is with the VVT in there, and depending on if it's inertia or solinoid operated, you can end up with what seems like low numbers but that are perfectly acceptable due to whether the VVT actually activates or not. (an inertia type won't spin fast enough on the starter to engage, while a solinoid type may, if there's adiquate oil pressure)
And then there's valve lash that can effect things too.
Cranking speed does have quite a bit to do with it also, so you might want to try and perk that up a bit before getting too worried about the numbers you're seeing.
I've heard 'safe' being anything from around 120-125 all the way up into the 150-160 and beyond range, depending.
Realistically you're looking for balance between cylinders before getting antsy about overall pressure. Basically even pressures mean even wear.
EG: your #1 is indicating it's the weak one by showing a 10-12% difference in pressure. The goal is usually 5-7% or less across all cylinders. (of course if you did #1 1st from dead cold and you have a solinoid VVT and oil pressure came up a bit by the time you got to #2 and the others.......)
Are you getting the impression there's far more variables involved than simply what a pressure gauge reads?
As to rev range type stuff, you do kinda have to work it like a motorcycle rather than what you would a normal car if you want to get anything out of it, though the S3's do tend to act a little better down low compared to the earlier versions. (not saying more powerful, just a bit smoother and more tolerant of revs under, say 3200. You still won't see peak power 'til around 5200 though)
Darren
'84 manufacture - '85 MY Spider Graduate
Old 05-27-2008, 06:26 AM
Bill S Bill S is offline
Those readings do look a lot like you didn't have the throttle blocked open. That's the range I always get whenever I forget to do that. Warming the engine will make a difference too. You can expect a lot of blue smoke from the oil you put in though.
I've never had an engine with VVT so I wasn't even aware of the oil pressure issue that Darren described. I'll try to remember that one.
Bill Sinclair
67 Duetto
69 Berlina (project)
73 GTV (project)
Old 05-27-2008, 07:06 AM
Carro-Kann's Avatar
I didn't test with open throttle. I will warm motor up and test with open throttle. Thanks guys.
