Old 05-24-2008, 04:36 PM
SpiderWebb's Avatar
SpiderWebb SpiderWebb is offline
Polyurethane Bushings are easy!
Hey, polyurethane bushing installation is a breeze! I got the IAP trailing links without bushings so I could install the blue poly bushings. See photos.
I understand the rubber bushings are a pain to remove and require them to be pressed in. I avoided all that with my choices and ended up with great performance bushings. These things go in with bare hands, until you put the steel insert in. With the steel insert, only the last inch requires something like a screwdriver round handle end to help push it home.
I used the supplied lube to coat every surface. Plan ahead so you don’t run out, and that’s about all that’s needed. I used my fingers to smear it evenly everywhere parts meet parts.
It’s an easy process.
1981 Spider 2000 USA - It's SpiderWebb cuz' Webb's my last name.
Old 05-24-2008, 04:41 PM
SpiderWebb's Avatar
Here is the metal insert being installed.
Nice looking finished product. Installation to follow.
Old 05-29-2008, 01:23 AM
the_sicilian's Avatar
the_sicilian the_sicilian is offline
Send a message via AIM to the_sicilian
thanks for the photos. my mechanic suggest that these trailing arms and also the sway bars, are the the spots most likely to get something out of the poly bushings.
i just bought some
what concerns me is the lube, and the fact that squeeking will begin alot sooner than rubber. we will see
/////////////////////////////////////////////////The Sicilian ~ Guido
1990 Spider motronic
1974 Spider 1750
Los Angeles, CA
If your wife has ever had to say, "hey move this thermostatic actuator so i can make dinner"...you might be an alfisti.
Old 05-29-2008, 01:28 AM
Tifosi's Avatar
Tifosi Tifosi is offline
Slacker
The lube is lithium based and you end up with a packet per end (couple teaspoons worth mabe) or at least that's how much used to come with them.
It's actually plenty quantity-wise, and there are grooves in the bushes to help retain a bit more of it in there rather than just letting it all squish out.
I've hand mine in for a couple years now and not a peep out of anything yet. :shrug:
In addition, the trunion to differential bush is another really good spot for poly.
Darren
as hosted by
Old 05-29-2008, 07:29 PM
ddouglas77's Avatar
ddouglas77 ddouglas77 is offline
Send a message via MSN to ddouglas77
Not sure about what brands you are refering to, but I know PST and Global West supplied me with silicone grease. Either way, nice job on the arms!
1990 Alfa Camaro Spider Super Sport Special American/Italian Edition. Pizza Burner with Pizzaz!
1974 Chevrolet Camaro
