Old 05-19-2008, 07:35 AM
jeremypacker jeremypacker is offline
Replacement of rear convertible window?
I just bought a 1985 Spider and the rear window is "fogged" up and after a few hours using multiple plexi cleaners I've given up on that route. I was initially thinking I'd replace the whole top myself, but after a bit of research on this site realize it might be a much more serious job than I first thought. As the top is in decent shape other than the window, I wondered if there is a DIY fix for this or if someone has hired such a job out? Maybe there is already an existent thread that I missed.
Any help would be much appreciated.
Jeremy
BTW--I'm in the Triangle area of NC so if someone has hired someone in the area for such a repair I'd appreciate that info as well.
Old 05-19-2008, 08:34 AM
MarkZ MarkZ is offline
No help on that issue, but after you have a clear rear window, always use something soft to keep it safe when folded. The rubbing of the plastic against itself, especially if it has any dirt or grit, will cause the yellowing much faster than you will want.
Mark
Old 05-19-2008, 09:59 AM
lgbalfa's Avatar
lgbalfa lgbalfa is offline
Send a message via AIM to lgbalfa Send a message via Skype™ to lgbalfa
usually people just replace the whole top instead of only the plastic window.
from threads that i have read to just replace the window you have to remove the top off and with the labor and everything it makes more sense to just replace everything.
some spider convertible tops have removable zipper windows but i am sure you would have mentioned it if that was the case for you.
1992 alfa romeo spider veloce, 19k miles
2000 saab 9-3 coupe, 20k miles
Old 05-19-2008, 10:24 AM
lowmileage's Avatar
ReAlfisted 3/06
With the labor cost involved, I don't know if it would make much economic sense to just do the window.
1973 GTV - bought 3/06 (quiet, he's asleep for the winter)
1969 GTV, #AR1530021 - sold 10/72
Old 05-19-2008, 11:08 AM
flaatr's Avatar
flaatr flaatr is offline
Wait... are you telling me you can drive the car with the top up?
Ok... any top shop / upholstery place can replace the rear window but as stated the labor doesn't change... the top needs to be removed for them to sew it in. I always thought if I went this route I'd put in a zipper'ed in window.
-Raffi
[SIZE="1"]-1974 Alfa Romeo Spider (still working on it)
-1980 Volkswagen Scirocco (Bone stock & original, 51K miles...)
-1987 Volkswagen Scirocco 16V (2.0L, Nothing stock or original)
-2003 Volkswagen Jetta TDI (Saves me money for the above)[/SIZE]
Old 05-19-2008, 11:09 AM
SpiderWebb's Avatar
SpiderWebb SpiderWebb is offline
This is a thread mentioning a zippered rear window. It does not remove, however, it just flaps down being zippered on only 3 of the 4 sides.
New Top For My S4
Originally Posted by slam105 View Post
Thanks!
I found a couple of different brands w/the 'zip-down-window':
Accessories convertible top Miata MX-5 Alfa Romeo BMW Ferarri has them on their site. Mine was recommended by my Alfa shop & is made(or sold by)E-Z ON AUTO TOPS, Inc.
Thanks again & regards.
1981 Spider 2000 USA - It's SpiderWebb cuz' Webb's my last name.
