Old 05-14-2008, 05:36 PM
gadwhite's Avatar
gadwhite gadwhite is online now
Senior Scottish Member
Throwout bearing difference
I have a thread on Transmissions, but I thought I would post this here to get more answers. I am changing the clutch on my 1985 Spider Veloce.
Here are the comparison picts for my throwout bearing (new on the left old on the right). Does anyone know why they are different? I am a little worried as the old one is a little taller/thicker than the new due to the collar that sticks out from the front.
Name:  Throwout new and old 1.jpg
Name:  Throwout new and old 2.jpg
Name:  Throwout new and old 3.jpg
Name:  Throwout new and old 4.jpg
1985 Spider Veloce,
Now 2008 Honda Element
was 2005 Honda Element ,
Old 05-15-2008, 04:01 PM
Gees, Gad, I wish I had an answer for you as to why this is so different. Ive never seen this before. Just put in a new one in mine a week ago. Maybe someone here will offer an answer.......
Old 05-15-2008, 04:15 PM
SpiderWebb's Avatar
SpiderWebb SpiderWebb is online now
Gadwhite, my old one is the same as your new one (1981 Spider). Not that it's very helpful, but it is more evidence the new one might be trustworthy.
The way the PO kept this car maintained, it's probably the original factory piece from 1980!!
1981 Spider 2000 USA - It's SpiderWebb cuz' Webb's my last name.
Old 05-15-2008, 05:19 PM
gadwhite's Avatar
Thanks guys
Spider and Joe
Thanks. I am curious if this is some sort of performance thing, butI think I will be ok because I am replacing the clutch disk and Pressure plate also. I will get them tommorow or Monday.
1985 Spider Veloce,
Old 05-15-2008, 05:28 PM
Tifosi's Avatar
Tifosi Tifosi is offline
Slacker
Hang around for a few minutes, I'll go see if I can dig up the old bearing I pulled out of mine and snap some pix.
Darren
'84 manufacture - '85 MY Spider Graduate
Old 05-15-2008, 05:31 PM
gadwhite's Avatar
Bearing
Darren
Thanks. I'm at work so want to head home, but I promise to check in about an hour.
1985 Spider Veloce,
Old 05-15-2008, 05:44 PM
Tifosi's Avatar
Slacker
K, here ya go.
What looks like rust is, (it sits in a box out in the garage waiting for some alternate use) but the bearing spins as free and quiet as the new one that replaced it.
No idea on how old it actually is/was prior to the swap as I've only had the car 5 years.
Darren
Old 05-15-2008, 07:42 PM
vf31rhill's Avatar
vf31rhill vf31rhill is offline
I would expect that the difference is that they are made by different makers. Wheather the new one will work as effectively as the old, I don't know. Where did you get the new one and whose box was it in? OEM for Alfa is Sachs of Germany. Many other makers in different countries also offer replacement cultches for Alfas, so that may explain it. I woud not install it until I got some assurance that it is correct for the Alfa. Way too much trouble to R & R a transmission just because some dummy sold you the wrong piece. Never assume that the parts you were sold are correct just because some low paid parts counterman pushed it across the counter or made up your shipment.
Robert
Old 05-15-2008, 08:45 PM
gadwhite's Avatar
good point
Originally Posted by Tifosi
K, here ya go.
Daren
Thanks looks like my new one is like everyone elses, and the old one is the bad one.
Originally Posted by vf31rhill View Post
I would expect that the differnce is that they are made by different makers. Wheather the new one will work as effectively as the old, I don't know. Where did you get the new one and whose box was it in? OEM for Alfa is Sachs of Germany. Many other makers in different countries also offer replacement cultches for Alfas, so that may explain it. I woud not install it until I got some assurance that it is correct for the Alfa. Way too much trouble to R & R a transmission just because some dummy sold you the wrong piece. Never assume that the parts you were sold are correct just because some low paid parts counterman pushed it across the counter or made up your shipment.
Robert
Robert
point well taken. The new one on the left came from IAP, and so did the clutch and pressure plate, thats will arrive Monday.so think Im OK
1985 Spider Veloce,
Old 05-16-2008, 06:41 AM
Alfar7's Avatar
Alfar7 Alfar7 is offline
Richard Jemison
Bearing Design
Bearings are designed to match the spring release fingers on the presure plates. Your "flat faced" new one will match the turned up tips as on later model pressure plates.
Richard Jemison
RJR Racing
http://scuderiagiallo.com
Old 05-16-2008, 07:05 AM
Andrew Andrew is offline
As far as I know, all the parts places list only one TO bearing for all 1750/2000 cars with hydraulic diaphragm clutch. Is the front face on your old one (the side that hits the diaphragm spring) dished? If so, I've never seen that. I've only seen flat surfaces there.
Andrew
Old 05-16-2008, 08:22 AM
SpiderWebb's Avatar
Gadwhite,
I got my new throw out bearing from IAP. It came with the Sach's Clutch and Pressure Plate Kit.
Here is a comparison of my worn out old one and the new Sach's bearing (on the right).
2 peas in a pod. I really wonder if the old one is the original? It's possible.
Articles
