Old 05-14-2008, 05:28 PM
BattleBug's Avatar
BattleBug BattleBug is offline
Oil Vapor Separator Horror Show Pt 1
I spent the last five weeks refurbing my motor's top end. I absolutely could not get the OVS cleaned out. I decided to peel off the lid to do a proper cleaning job--check out what I found--no wonder the oil drain line was always clogged up!
Holey cow! They must've used some of that Russian steel in this thing. I first soaked it in carb cleaner, then naval jelly, and finally blasted it with 70 grit aluminum oxide. The non rusty metal left behind was paper thin, obviously unusable. Needless to say the corrugated brass filter(?) was shot. See part 2 for my solution.
Paul
'86 Spider Graduate
Old 05-14-2008, 05:52 PM
msiert's Avatar
msiert msiert is offline
Holly Crap what a mess, always wanted to see one of those things apart.
Murray
1991 Black Spider
The "Black Spider" project
Street Video
Track Video
Old 05-14-2008, 06:05 PM
BattleBug's Avatar
Oil Vapor Separator Horror Show Pt 2
These items are obviously NLA and I had no desire to go the used route. After a few days web surfing I came to the conclusion that the only comparable replacement was for Continental/Lycoming aircraft engines and they were entirely too large. Moroso, etc were close but still not quite right. I finally stumbled on the website of a V12 Jag owner (sorry, link escaped me) who showed a hardware store solution. I made my version using parts readily available in Lowe's/Home Despot's plumbing section: 2" ID PVC (I used ABS), matching end cap & cleanout plug, some 1/2" & 3/4" copper fittings, a little JB weld and some scrap fittings from my junk bucket. The mount strap is a piece of aluminum strapping bent like a coil bracket. The "filter" element is a wad of stainless steel potscrubber stuffed down inside. Finishing touch was a little gloss black spray to make it not-so-much-an-eyesore. The best two parts are that I can pull the cap off anytime I want and clean it out AND less than $25 invested. It remains to be seen how well the copper and ABS will hold up to the acidic crankcase vapors, galvanic corrosion, heat, etc but I'll update results at my 500 mile re-torque.
Size:  42.5 KBName:  MySol2.jpg
Size:  51.5 KBName:  MySol4.jpg
Paul
'86 Spider Graduate
Old 05-14-2008, 06:18 PM
msiert's Avatar
Nice job, BattleBug!
Murray
1991 Black Spider
Street Video
Track Video
Old 05-14-2008, 07:08 PM
Elio Comello Elio Comello is offline
Super creative BB!
Only think I see is that the inlet vapor connection could have pointed around the circumference to get some swirl, not straight down...
You win first prize for innovation for sure!
TTFN Elio
Old 05-14-2008, 07:58 PM
velocedoc's Avatar
velocedoc velocedoc is offline
Christopher Boles
I know exactly what you are experiencing with a separator all plugged up. My wifes spider separator was so badly plugged..it took me two evenings of pounding on the sides with a plastic mallet and pounding the unit upside down on a wooden plank to get all the gunk that has froze up inside. Once it was free of any junk falling out, it works perfectly again. Thanks for taking that apart..I wanted to know what it looked like inside. Did you try APE for a unit?
Old 05-14-2008, 11:20 PM
Caroni's Avatar
Caroni Caroni is offline
Awesome Job and some great creative thinking. just had to throw in my kudos to you. I love it when ingenuity beats out NLA.
David
1967 Mustang fastback perpetually under construction?
1984 Alfa Spider
1984 Volvo 244 GLT now being gutted for project parts
1999 Taurus (gets me to work and back)
1974 Chevy 3/4 ton hauls the leftovers away
Old 05-14-2008, 11:56 PM
Rich's Avatar
Rich Rich is offline
Bravo Paul, or should I say MacGyver.
Rich
Old 05-15-2008, 05:28 AM
WopJob's Avatar
WopJob WopJob is offline
How about getting rid of the thing alltogether and venting the head to the athmosphere via a generic check valve and hose that reaches the ground?
you would have to plug the oil return, vacuum nipple, and vapor return to the throttle body. Other than obvious pollution concerns isn't this what the S1 and S2 had?
I've seen some pictures in this BB where the hgead was just vented out with a small round filter attached to the head cover.
I clean my oil/vap seprator every year and after seeing Paul's picture I thnk that I'm just kidding myself that the thing is still usable.
_________________________________
Tony G.
in NJ
87 Graduate
90 Toyota Tercel - uncool daily driver
Old 05-15-2008, 05:52 AM
Farace's Avatar
Farace Farace is offline
I can't speak for an S1, but my S2 has the vapor canister.
Bob Farace
Old 05-15-2008, 06:04 AM
rcess's Avatar
rcess rcess is offline
My '69 Spider also has the vapor canister.
Bob
'59 Giulietta Sprint
'60 Giulietta Berlina
'62 Giulietta Spider
'69 Spider Veloce
Old 05-15-2008, 06:06 AM
Alfacliff Alfacliff is offline
My sons 69 spider has 0ne. what you want to do, lower our alfas to the level of 70's american cars?
I made up one for a while out of a oil bottlewith some holes drilled into the cap for the hose and a vent, didnt get hardly any oil in it, a very good cleaning of the vapor seperator and replacing the return hose fixed most oil leaks and gas smell in my 74 spider.
cliff
Old 05-15-2008, 06:11 AM
papajam's Avatar
papajam papajam is offline
in the Library
I've read that the 164 (or was it the Milano) separators work just fine. And being made of plastic, no rust.
Series 1 Euro 1750 GTV
Series 2 US 1750 GTV
Series 3 Spider Veloce
  #14 (permalink)
Old 05-15-2008, 06:27 AM
WopJob's Avatar
sorry guys I don't have an S1 or S2 but I've seen many pictures of engine bays in this BB of these cars. Also what have the owber of S1 and S2 done about this problem, certanly their cars being older the oil/vap separator must have crapped out many years ago.
Tony G.
in NJ
87 Graduate
  #15 (permalink)
Old 05-15-2008, 07:37 AM
spidryell spidryell is offline
I went the used part route after I found mine had basically rotted out from the inside. I cleaned up the replacement unit with solvent and then sprayed fogging oil into the inlet to see if it was functional. Worked -- liquid not foam came out the oil return line at the bottom and only vapor came out the large fitting in the bottom. I then gave the entire unit a spray of fogging oil to keep the corrosion at bay. I plan on cleaning and spraying fogging oil into mine once a year.
Steve
______________
82 Spider Veloce
Articles
Copyrigh
