  #16 (permalink)
Old 05-11-2008, 06:53 AM
Chsmadden's Avatar
Chsmadden Chsmadden is offline
Originally Posted by tulsalfa View Post
I ran one tank of 87 octane gas (by mistake) through my 86 Grad with no noticeable effect. I do add a bit of Lucas Gas Treatment with each tank. Has anyone had any experience with running less than 91 octane gasoline? Will the computer reset for the lower grade? Am I causing some unseen damage by running 87 octane either4 sporadically or even constantly? Any advice would be MOST appreciated.
Dean
You will be fine if it's a bone stock engine(8-9:1 CR). Higher compression engines need higher octane gas to keep them from pre-igniting/knocking. If it has a computer, any car can run on any gas(except diesel). Older cars w/o knock sensors and EFI just keep on knocking and that is really bad for the engine.
Chris Madden
1974 GTV (Carbureted )
  #17 (permalink)
Old 05-11-2008, 09:06 AM
maxwedge's Avatar
maxwedge maxwedge is offline
I run 87 in all my vehicles, even though the turbo Celica says "Premium Fuel Reccomended for best performance". Of course, they wrote that back in 1989 when gas cost 1.10/gal. It's been running fine on 87 for 20 years and 170K highly abusive miles. I noticed last night when I filled up my truck last night it was almost .50 more (4.15) a gallon for premium here in IL. Which reminds me, does anybody want to buy a thirsty, high compression V8 powered jet boat, with a 30 gallon tank?
  #18 (permalink)
Old 05-11-2008, 10:05 AM
Garry-Graig's Avatar
Garry-Graig Garry-Graig is offline
Originally Posted by papajam View Post
The half dozen or so mid 1970s 2000 Euro owners manuals I just looked through all recommend the use of premium fuel (no octane listed).
Thanks for the effort,papajam!
1976 Alfa Romeo 2000 (Euro,RHD)
2003 Alfa Romeo 147
  #19 (permalink)
Old 05-11-2008, 12:28 PM
Oski_Bear Oski_Bear is offline
Dang..and here I am using 91 all the time.... time to switch!
1988 Spider Graduate
  #20 (permalink)
Old 05-11-2008, 01:16 PM
Chsmadden's Avatar
10.4:1 Pistons is probably a bad candidate for 87 isn't it.
Chris Madden
  #21 (permalink)
Old 05-11-2008, 03:00 PM
Bill77's Avatar
Bill77 Bill77 is offline
I've heard that the 10.4:1 pistons like to be run on 91 or more, but haven't tried it on my yet-to-be-started (and yet-to-be installed) 2L.
I'm curious what others will say...
Bill
1977 Spider
2000 Aprilia Mille
  #22 (permalink)
Old 05-12-2008, 05:30 PM
Giovanni2000's Avatar
Giovanni2000 Giovanni2000 is offline
Member
I run 87 in my 82 Spider with no problems, 87 in my Honda, 89 in my Infiniti and 100LL in my Skyslug I mean Skyhawk...I have noticed a difference in smoothness between Chevron and Shell, so I use Chevron as much as possible...
"With enough speed, anything will fit!!"
________________________________
1982 Spider Veloce-Cruiser Car
2003 Infiniti G35 Coupe-Go Fast Car
1990 Honda Accord-Beater Car
1977 Cessna 172 Flying Machine
  #23 (permalink)
Old 05-13-2008, 06:32 AM
lowmileage's Avatar
Nothing but 93 for my baby
  #24 (permalink)
Old 05-13-2008, 10:21 AM
msiert's Avatar
msiert msiert is offline
I'm using 92 gas in my Spider w/o knocking and I have a 10.5 CR....................Can't find 93 in Nebraska.
Murray
1991 Black Spider
The "Black Spider" project
Street Video
Track Video
  #25 (permalink)
Old 05-13-2008, 01:39 PM
BlueSpider's Avatar
BlueSpider BlueSpider is offline
Very interesting. Question I had for sometime. I am using 91 all the time on my 88 Spider and I know previous owner was running on 91 as well. From what I read it appears I am wasting money more than anything else. I shall try 87
Brian (alias BlueSpider)
1988 Spider Veloce (112K miles - daily driver)
1973 GTV (restoration project)
2 other more recent German cars (but who cares)
  #26 (permalink)
Old 05-13-2008, 01:49 PM
Andrew Andrew is offline
If your timing is reasonable, my experience is you have to be pretty abusive to get a Spica car to ping or knock; they're pretty resistant to it. Carbed cars will ping more easily.
I use the highest octane I can get, which where I live in Calif. is 91. I think 87 is asking for trouble, unless you're at high altitude, which 1000 Oaks is not. Make sure to keep your ear tuned for pinging or knocking while trying 87.
Andrew
  #27 (permalink)
Old 05-13-2008, 01:51 PM
Thought, but did not state: I am not sure how sensitive Bosch cars are. L-Jet cars do not have knock sensing and cannot retard the spark if pinging is detected. Motronic cars I don't know about.
Andrew
  #28 (permalink)
Old 05-13-2008, 02:34 PM
BlueSpider's Avatar
OK noted. I have L-Tronic indeed. I am happy to stick with 91 if that's what is best. Let me have a chat with my mechanic later today. Thanks again.
  #29 (permalink)
Old 05-13-2008, 02:40 PM
If you're aware of the hazard, and know what to listen for in knocking and pinging, I don't see the harm in trying 87 to see how it goes. If the car is loud, or there's lots of wind noise, you do risk not being able to hear pinging or knocking. But I'd expect you'd be OK if you go carefully. Of course, if you drive too carefully, it won't knock or ping.
To get knock or ping, try the proven combination of low rpm, large throttle opening, and high ambient temperature. Guaranteed to ruin your engine. Also hard on rod bearings.
My wife's 97 BMW 328i pings on Calif sea-level 89 octane; not sure what generation of Bosch engine management it has; Motronic something, and presumably knock sensing and spark retard?
Andrew
  #30 (permalink)
Old 05-13-2008, 02:48 PM
BlueSpider's Avatar
Thanks Andrew - and no I'm no expert in determining the knocking thing, unfortunately
Articles
