Duetto Motors Top - Alfa Romeo Bulletin Board & Forums
Old 11-09-2004, 08:06 PM
John M's Avatar
Duetto Motors Top
I thought I would share that I had great luck with installing my new Duetto Motors Top on my 92. The top has gone through some changes since I purchased one for my 78 a few years ago....all for the better.
One change included the addition of eye-lets for the top cables to run through. These eye-lets are above the window corners at the b pillars. Top also came with strings threaded through the pouch to easily pull the top cables through the top.
Another change is in the window attachment. The window is now double stitched in. Previously it was some way glued/heat sealed. The double stitched in window looks more original and very similar to the original top.
Now for some issues. The T bolt pocket is missing. But this was easily resolved my making a slit and placing her inside the padded corner. The edging at the center of the top where it meets the windshield still needs improvement. Nige noted this in an earlier post. And finally no chalk marks across the back. This was easily resolved by laying the old top out and using it to chalk the new top.
The top installation went fairly easily and fit perfectly the first time. I pulled the frame for the installation. Then installed the front and around the windows first, prior to fitting the back to the studs...going off my chalk marks from my old top. Best advice in fitting the back is to get the little significant other....for me my wife Lisa..... to sit back there and put the top on the studs while you make the slits. The Hartz Sonnedeck material that I chose has a pattern sewn into the headliner. Common material used on Bimmers and Mercedes. Around $320 including shipping. And it passed the fellow Alfisti test of approval.
Best Regards,
John M
[SIZE="1"]1978 AR Spider Veloce 2000....the first and still here...Bianco
1984 AR Spider Veloce............the second & gone to the parts bin....Rosso
1992 AR Spider Veloce............the third and still here...Bianco
1991 AR 164L........................the fourth and traded on the SS....Rosso
1965 AR Sprint Speciale..........the fifth...in boxes....sold....Bianco
1978 AR Spider Veloce 2000....the sixth gone to be a parts car...slow black
1982 Ferrari 308 GTSi.............the first, fresh restore....Azzurro[/SIZE]
Old 11-09-2004, 08:18 PM
GTD's Avatar
GTD GTD is offline
John
Did you do step by step detailed pictures?
Did you buy the padded sides?
Alfa Sapiens
Old 11-10-2004, 08:01 AM
John M's Avatar
Unfortunately...I didn't take any step by step pictures. There is a really good installation guide out there and if you don't have it PM me.
I did get the padded quarters. Speaking of options, Duetto Motors also have options for zippered rear window, tinted rear window in various colors, but alas no glass rear window.
Forgot to mention...got the top within a couple of weeks of the order. Great service as before.
Best Regards,
John M
Old 11-11-2004, 01:53 PM
John-
My Duetto Motors top had a heat welded window, from the outside, which looks cheap.
I believe they use multiple suppliers for their tops, they do not make them.
Regards,
Clark
Clark
'74 Spider
Old 11-11-2004, 02:02 PM
Farace's Avatar
I can say, based on my experience with their top boots, they do listen to customer complaints and try to rectify them. The first boot I got from them had straps that were too short to reach the turnbuttons if the rest of the boot was snapped down. In fact, one of the straps ripped off its rivet while I was trying to snap the boot down. I contacted Duetto, who put me in touch with their supplier. They modified the design so the strap is now elastic, and sent me a new top boot.
Bob Farace
1987 Alfa Romeo Milano d'Oro
Director, Connecticut branch, Scuderia Non Originale
Old 11-11-2004, 03:43 PM
John M's Avatar
Hey Clark:
You are correct in that 1. they don't make them as George stated....and 2. the old way they were doing the rear window was heat sealed on to the material (my 78's top is this way). But as I noted in my first message, this has changed. They are now double stitched into the material as the original Alfa top. Bob points out a very good point.....they do listen to the complaints. I addressed the concerns people have brought up here directly with Duetto Motors prior to purchasing my latest top. I encourage others to do the same.
All and all, this top is a steal and is only getting better.
Best Regards,
John M
Old 11-17-2004, 12:03 AM
nzspider's Avatar
Hi guys
My info is that you have to ask for the stitched rear window when buying the Haartz Stayfast top. The one Duetto sells on eBay is heat sealed. Here is Duetto's reply to a friend's query about whether the eBay top had a stitched window:
"The auction top is made with a heat sealed rear window. We can supply you with an Alfa top made with a stitched rear window for $299.95 plus $19.95 S&H. These tops are made to order from Black Stayfast Cloth and feature padded quarter panels. Tinted plastic windows are available as a $35.00 option."
cheers Nige
1978 Spider (UK RHD 105)
Old 11-17-2004, 04:16 PM
Bill77's Avatar
Still sounds like a good deal to me.
Bill ---- 1977 Alfa Romeo 4C2000 ---- 2000 Aprilia RSV Mille ---- 2012 BMW S1000RR
Old 11-17-2004, 10:32 PM
John M's Avatar
Hey all:
I have been talking over the last few weeks with Gerry from Duetto. All I have to say is praise. I have been bringing up some of the finer details of their top that has been problematic. And Gerry has been very responsive. We have been exchanging photos, chatting live on the phone.....and discussing what can be done to improve the top even more. So here is that info:
1. Nige had pointed out in the past about the edging being joined at the center of the windshield and having an unfinished edge. After talking with Gerry and showing him Nige's photo as well as one from my latest top, I found out that Gerry thought that area was not visible when the top was up. He has now taken the action of informing is manufacturer that the edge is incorrect. From my understanding that now will be either one continuous piece or it will have a finshed edge and be joined exactly at the center of the top.
2. Eyelets for the cables......now included.
3. Stitched in rear window. The manufacturer has switched from the heat glued in window, to the double stitched in window. My latest top arrived with a double stitched in window and I did not request it. But my top was special order using sonnedeck material rather than stayfast. So if you are placing an order today....be sure to request the double stitched in window if you want it....otherwise you will be getting one from their old stock. Gerry was not aware that the manufacturer had made the switch until I told him. I also told Gerry that the original top had the double stitched in window and to keep them coming that way.
4. T bolt pouch. The most current top lacks them. I sent some pictures over for Gerry to share with the manufacturer to get this added. I haven't heard the outcome on that yet. Gerry actually sent me an email requesting the pictures so he could work on that as well.
5. Prepunched holes or chalk marks. Probably not going to happen across the back. Gerry thinks that there might be some variation in stud mounting positions from car to car, year to year. So they don't want to punch holes and have them turn out to be in the wrong place. I can see his point. But does anyone have info on whether there is variation or not? If you do....share it with them.
So I will chalk Duetto as being pretty darn responsive to our concerns. I can say I have been very happy with them. Just order specifically what you want and ask for the top the way you want it....and my money is on that your top will arrive that way.
Best Regards,
John M
Old 11-18-2004, 05:07 AM
Farace's Avatar
The cheap top that came with my car (uninstalled in a box in the trunk, no brand name) had prepunched holes and I had no problem installing it. For the record, this top did not have eyelets or T-bolt pockets, so it's not the greatest top. I believe someone mentioned in another thread a while ago that the top IAP offers has prepunched holes. So this seems to be something that is doable. Has anyone ever had a problem with prepunched holes not fitting?
I did note, however, that there was a difference in the number of holes on the top and the number stated in some instructions (I can't remember if those particular instructions were in the installation manual or in the Alfa Bible.) I believe it was 22 versus 23. The top had the proper number of holes for my car. Maybe later cars had a different number?
Bob Farace
Old 11-18-2004, 08:55 AM
Location: 1613 E. Clover St. Casa Grande, Arizona 85122
Contact info for Duetto tops???
I would like to get the contact info for the Duetto top people. I have a '67 duetto that I am rebuilding the suspension on, and getting ready to sell, and the price of the top seem reasonable enough, that I should replace the existing one for the next owner.
Thanks, George
Old 11-18-2004, 09:01 AM
John M's Avatar
Hey George:
Their phone number is (818) 727-0969 and they are located on the web at www.duettomotors.com. I don't know what the pricing on a duetto top is....but they show it listed as one of their products. I think its a little more than the spider top...maybe $100 more.
Best Regards,
John M
