There's a switch inside the wiper motor that operates when the motor is in it's "park" position. As well as being necessary for parking the wipers in the right place, the intermittent wiper circuit relies on this switch to work properly. So, from your description, the problem is almost certainly with the park switch or it's wiring.
So first port of call is to trace the wiring, looking for bad connections, especially where the wires are soldered onto the wiper motor (certainly on older spiders).
Next, the switch itself is inside the wiper motor's gearbox. You can disassmble the motor to inspect the inside of the gearbox. You're not looking for a switch as such, but a couple of contacts which press against the main gear as it revolves. The gear has sections of conducting and non-conducting material on it, which make/break the circuit as they pass under the contacts. If you are getting intermittent behaviour, it's possible that the grease in the gearbox is interfering with the this process. Alternately, it's not unheard of for the gearbox to fill up with water and similar problems being caused by corrosion.
Unfortunately, it's a bit of a pain to get at the motor for inspection, but very satisfying to figure out how it works (no rocket science in there) and fix it - normally just a case of cleaning up and applying new grease. Just be careful of the carbon brushes in the motor.
ocduff - have you tried just blowing through the tube that leads off to the sprayer nozzles - can be remarkably effective, either for diagnosis or for actually fixing the problem!
Dan.
It's not beige, it's Ivory. I'm gutted.
