Hi everybody,
I'm a recent Alfa owner - an '83 Spider Veloce, in that rare light green colour you don't see too often around. Apparently pretty stock considering it came with original headlight covers, and has that downturned exhaust.. I'm in Victoria, BC - a student at the University here, working on my Economics and Business degree. I've been lurking the board for the past couple months and have to say thanks to the author of the wiring diagram - I had an issue with her not wanting to start, but figured out it was a bad connection with the fuse (eventually, with the help of said wiring diagram
) Anyhow on to the problem at hand..
Any ideas as to what I should take a look at would help - I'm not a mechanic, and a 'starving student' so please keep these in mind when coming up with any ideas..
She was running absolutely fine, brilliant, spectacular.. until one night when I did a lot of driving back and forth along the highway.. I was on my way home, so I had come back down to city speeds and noticed a strange sound eminating from the underside: It sounded like metal-on-metal scraping, but sounded cyclical.. I immediately pulled over and shut her off.. trying to start her again, all I got was horrible starter-grind, and rolling down a hill to roll-start didn't do anything either, all she would do is grind to a halt.. after rowing through all the gears, I finally felt something move and started her up again and limped home.. with this crazy noise that sounds to be coming from the gearbox.. description of the noise is as follows:
sounds like metal-on-metal rubbing together, not constantly, but in a cyclical pattern ('whissh-whissh-whissh' kind of noise). Next, it's linked to the engine rpms, but not exactly.. adding gas speeds up the noise, but it's delayed a bit.. kind of like when a turbo spools up.. say, when i up the rpms and then push in the clutch, the sound will 'spool' up and then 'spool' down a little delayed after engine rpms.. Additionally, pushing in the clutch takes away the noise a bit..
Now, this does seem to have an effect on starting the car, too.. starting her cold or hot sometimes gives me that starter-grind kind of noise.. the one way i was able to start her last was to put her into reverse and rock the car back and forth before being able to fire her up. Hoewever, this issue doesn't have an effect on performance of the car.. she still pulls fine, plenty of power and gear shifts are as they were before.. And the last time I took her out for a spin to warm her up, by the time i was coming home, (45 mins later, after sunset, cool air temperature) the noise had settled down, barely inaudible..
I greatly would appreciate *any* input, advice, things to check, things to get a mechanic to look at (ideas how to get a mechanic to do this for cheap or free would help too.. i hear they like beer? funny, so do i
), or ideas on what to replace, costs, etc..
Kudos to those of you still reading this essay, I look forward to hearing any and all replies. I haven't been driving her much, as I want to figure this out, and hopefully not damage anything further..
Thanks a ton, everybody!
-Mike in Victoria
