High-RPM hesitation when Cold
Hello all,
Below is a challenging problem that numerous gurus have yet to solve:
1986 Spider Graduate (L-Jetronic) with 108,000 miles. The following describes the problem:
When cold, the car hesitates, as if governed, beginning around 3,700 rpm. As the car warms up over several miles, the "governer" raises its limit - eventually, the problem goes away. There is a sticking point at around 3,900-4,000 rpm, but once the engine is able to rev above 4,000 rpm, it takes only about ten more minutes of driving to have normal access to the entire rev range. However, the first number of trips above 4,000 reveals a sluggish feel as if the mixture is lean.
The following have been changed/checked:
1) new temp sensor
2) new fuel filter
3) new in-tank fuel pump
4) new plugs (what the heck!)
5) Auxilliary Air valve removed, cleaned, tested (works great) and replaced.
6) Fuel lines (metal and rubber).
7) VVT Solenoid - re-mounted - works great.
The car is driven daily. Regardless of the weather, it starts immediately, idles perfectly, and, if you are a short-shifter (below 4k rpm), you'd never know there was a problem with the car. The problem is very much temperature-related because the hesitation is worse the colder it is outside and therefore takes longer before it disappears. Once the problem does clear up, it won't reappear until the car has sat for over 12 hours. I have a used airflow meter on its way to me right now, but I'm not convinced that this will help.
Any ideas are welcome.
Thank you,
Drew.
