emissions inspection failure
Well...not surprisingly I guess my 86 quad failed the very stringent Mass inspection today...only one spot though, the HC reading was 3.43 and the limit is 2.0. The car has not been driven much, very sporadically, over the last 5 or 6 years, and the guy doing the inspection said it probably needed to be driven through a few tanks of gas, new plugs and wires maybe if not a little tune up..maybe a sensor, maybe some injector cleaner. Does this all sound like good advice...I know this failure means it's not burning fuel correctly. I intend to drive it through a few tanks of gas and then try and get it to a local alfa mechanic for a check up. Too bad, it seems to run really well and I hope it's nothing too major. Any suggestions are welcomed...I knew it was too good to be true and it was going very smoothly.
