On the road again
Well, bought insurance and plates (they go together here) and went for a 30 minute drive. Handles fine. Steering good. Rattle in driver's door. Clutch is pretty bad. Slips a lot. Gears are average. Long as I hesitate in neutral going up and double clutch down, no grunch. Engine, for some reason, is running on 3.5 cylinders. (No obvious miss, but no power.) Had it out a month ago (illegally) and went much better. Can't imagine what I could have done, as I've been working on electrics and the top. No valve noise, apart from lack of power sounded fine.
Pulled the plugs. Number three is pretty black, but others are clean. Attached wires, laid plugs on head, turned engine over. Good sparks. Cleaned plugs, pulled leads, cleaned ends, checked cap (fine) went for another drive. Same thing. Next comes a compression check. I'll report back.
Ian Cameron, 1980 Spider
