Old 04-11-2008, 04:59 PM
chpopel's Avatar
chpopel chpopel is offline
front cover leaking...help
my 1976 spider is leaking antifreeze.at first i thought it was the water pump, but soon discovered it is leaking from the front cover(cam cover?).what are my options? is it easy to fix,or does everything have to come off? [ATTACH][ATTACH]Name:  P5110112.jpg
Size:  63.2 KB[/ATTACH][/ATTACH]
1976 spider
2007 toyota camry hybrid,2003 toyota seinna
Old 04-11-2008, 06:05 PM
ghnl ghnl is offline
You can try some 'stop leak' additives in the cooling system but those are usually only a temporary repair (if it even works at all).
There is a gasket between the front cover and the engine block. Lots of stuff to remove to get to that gasket.
Have you made sure all the nuts holding the front cover are tight?
- - Eric
don't read this
~ 1984 Spider Veloce ~
Mebane, North Carolina
Old 04-11-2008, 06:31 PM
ossodiseppia's Avatar
ossodiseppia ossodiseppia is online now
pffffffffffffffffffffff!!
I must be blind, I don't see anything
Old 04-11-2008, 06:33 PM
Picture #2 shows it pissing...
- - Eric
don't read this
Old 04-12-2008, 07:31 PM
chpopel's Avatar
is it only the four lower stud nuts that hold the cover on?the water pump nuts seem to be a bit loose...
1976 spider
Old 04-12-2008, 07:38 PM
IIRC, the upper studs are extra long and pass through the front cover and the water pump.
Tighten the water pump nuts!
- - Eric
don't read this
Old 04-13-2008, 09:17 AM
chpopel's Avatar
thanks,hopefully thats my problem...
1976 spider
Old 05-18-2008, 01:55 PM
chpopel's Avatar
Is there no way of removing the front cover without removing the cylinder head?
1976 spider
Old 05-18-2008, 02:07 PM
Tifosi's Avatar
Tifosi Tifosi is offline
Slacker
Should be able to pull it without taking off the head.
The only thing that I'm aware of that hold the chaincase cover to the head are the two small bolts that go up into the front corners of the head.
However you'll definitely need to remove the crank pulley (duh) and most likely break the upper cam chain as the tensioner is part of the cover.
Darren
as hosted by
Old 05-18-2008, 03:16 PM
papajam's Avatar
papajam papajam is offline
with the Librarian
It might be possible to remove the timing cover with the head on but trying to install it without damaging the head and oil pan gaskets will be a challenge of the highest order. The proper way is to remove both the head and the upper oil pan.
Series 1 Euro 1750 GTV
Series 2 US 1750 GTV
Series 3 Spider Veloce
Old 05-18-2008, 03:34 PM
Is this an old style engine, unlike the 87 spider I have?
Old 05-19-2008, 05:31 PM
chpopel's Avatar
thank's everyone. will remove the head when i have time and money.....
1976 spider
Old 05-19-2008, 07:01 PM
Bob Sacamano Bob Sacamano is offline
The block casting looks a little different, but it's basically the same. The biggest differences were in the timing covers (spica, carbs, bosch, etc.).
