Old 04-10-2008, 04:25 PM
nickster60 nickster60 is offline
Water Pump Stud Questions
Do the studs ever break off when double nutting?
Is it possible to apply heat to them to help with removal?
Is it just easier to remove the crank pulley?
Can use the breaker bar on the crankbolt and set breaker bar on the ground and hit the key? It always worked on my Volvos.
Do Centerline and International sell the same brand of water pumps?
Florida
1977 Alfa Spider
1978 BMW R100/7
2001 Kawasaki Concours
1985 F-250 Diesel
2004 Scion xa
2005 F-150
Old 04-10-2008, 04:48 PM
he3r0's Avatar
he3r0 he3r0 is offline
Send a message via Skype™ to he3r0
Red face
Yes, but they also break while trying to unscrew the nut...
it may help, also little of pb blaster would not harm
I replaced waterpump without oulling off pulley, but next time (if there will be next one) Im taking that crank pulley off....
theory sounds good, if you have enough clearance it should work, but maybe you will consider some power tools?
and that is a good question, that I have no answer for...
Maciej ---> Ex: CITROEN GS 1220`78, NISSAN SENTRA`94.
Now VVO 960 `97, VVO 940 `94, SPIDER GRADUATE `85
Old 04-10-2008, 06:55 PM
IF you remove crank pulley, put in a new crank seal, if it has any leak of oil around it. LUBE it well before putting it on, or you can damage the lip.
