Old 10-01-2004, 01:25 PM
Steve Brown Steve Brown is offline
Driveline Center support
I believe that my driveline center support needs to be replaced. I have a 91 Alfa Spider Veloce. Any ideas on how difficult this is to do? If an Alfa shop was to repair it how many hours would be reasonable?
Steve
Old 10-01-2004, 01:37 PM
Roadtrip's Avatar
Roadtrip Roadtrip is offline
74 Alfa Spider
Steve - Do a search on the BB. There are several threads that answer that very question. In short, it's not hard, but you have to keep the orientation of the driveshaft the same when you reinstall.
John Stewart
74 Spider
Old 10-04-2004, 09:09 PM
alfaloco alfaloco is offline
Stve- just curious. What symptoms make you believe the center bearing needs to be replaced? Vibration? Noise? Both?
Dave Jarman
Lexington, KY
USA
'91 Spider (red)
'94 Spider CE (yellow)
Old 10-06-2004, 05:11 PM
Primarily a chattering when taking off under a load ie as when you are on a hill.
Steve
Old 10-06-2004, 06:11 PM
conedriver's Avatar
conedriver conedriver is offline
George Schweikle
Steve,
Please document whatever you do to your '91 spider. I have one also, and it is just starting to display a similar symptom at 42,000 miles (chattering or vibrating when starting). My initial thought was a loose universal joint. I will crawl under the Silver '91 when the season is over for the red '76 Spider, and maybe will find an "assignable cause" (that's quality assurance talk...).
Steve
Regards,
George Schweikle
Scuderia Non Originale
Old 10-06-2004, 06:47 PM
Paradiso's Avatar
Paradiso Paradiso is offline
Have you checked the transmission mount bushing? That's the most likely cause.
92 Spider Veloce
71 TwinSpark Spider - Soon to be 4 Sale
Old 10-06-2004, 08:26 PM
My '91 Spider developed a shudder on initial takeoff at about the same mileage, 40K plus. I checked the transmission mount, and it seemed soft and overly pliable, allowing too much vertical movement. I compared the "feel" of the rubber bushing with a new molded piece, and decided to change it out. When I dropped the driveshaft, I checked the u-joint also and it was very floppy in both axes, so I replaced it also. So, I cannot say which fix cured the problem, but it was gone. The car has the original center support bearing now with over 58K miles, including autocross standing starts.
For this reason, I asked about the symptoms. Both the u-joint and the transmission mount are easier to replace than the center support bearing. Frankly, if any roller or ball bearing in use feels smooth in rotation, rolls evenly, and lacks any free play and noise, I would leave it alone!
If you pull the driveshaft, be certain to mark all sections in exact relation to each other because it is a balanced assembly! Mark the u-joint flanges and the splined end also. Lube the spline moderately at the grease fitting, but don't overdo it.
Dave Jarman
Dave Jarman
Lexington, KY
USA
'91 Spider (red)
