Old 04-07-2008, 07:59 PM
greg's Avatar
greg greg is offline
1969 Roundtail Numero Uno
Oil consumption after complete rebuild
What should be oil consumption after rebuild. Regular rebuild with hastings oil rings. Using 10w-40 valvoline. first 350 miles used about 1/5 quart.
Should it improve after first 1000 miles ?
I will change oil to 20w-50 and retorque head after first 750 miles.
Thx
1969 1750 boat serial 105.62.14800001 Numero UNO
ex 1992 spider can't afford 2
ex 1986 alfa33s
Old 04-07-2008, 08:19 PM
ghnl ghnl is offline
1/5 of a qt in 350 miles seems good. That'd be about 1750 miles/qt.
How are you 'breaking in' the rings? There is some controversy about the best method. Conventional wisdom says drive it easy for a while. Then there is the flog it method. Break in secrets
- - Eric
don't read this
~ 1984 Spider Veloce ~
Mebane, North Carolina
Old 04-07-2008, 08:40 PM
greg's Avatar
I'm going easy to at most 3700 rpm. only once slipped and went 95 mph at 5000 rpm
ex 1986 alfa33s
Old 04-08-2008, 03:12 PM
mikeori's Avatar
mikeori mikeori is offline
member
your consumption seems to be pretty good. I've rebuilt several engines (not alfa), and
have always believed that you want to seat the rings in the bores by placing a load on
the engine - best method seems to be to accelerate at full throttle from 30 to 50 mph
and do it repeatedly. hope this helps
Old 04-08-2008, 03:52 PM
sgtpeper sgtpeper is offline
I too break in engines the hard way. I cant remember where but theres a great article on how to break in an engine hard - the RIGHT way.
Either way have fun!
Old 04-08-2008, 04:02 PM
Originally Posted by sgtpeper View Post
I cant remember where but theres a great article on how to break in an engine hard...
You mean this article: break in secrets?
- - Eric
don't read this
Old 04-08-2008, 04:12 PM
Haha yea thats the one...
I broke my STi in pretty hard. Most people with STis burn oil - I dont, so theres something to be said for a good hard break in.
Jeff
Old 04-08-2008, 04:25 PM
wutdhec wutdhec is offline
Member
Any thoughts on whether its better to warm up the car or not before driving?
I've heard that on 911 SCs its actually best to skip warm up in the garage and just keep RPMs below 3000 until the engine is warmed up...
Hector
'91 Spider Veloce
Old 04-08-2008, 04:43 PM
Thats interesting. I always warm my car up fully before really pounding on it. I have an oil temp gauge and I wont get into boost until its at 180 degrees.
Jeff
Old 04-08-2008, 04:58 PM
Gary Williams's Avatar
Gary Williams Gary Williams is offline
For future reference, here's the link to the Hastings "how-to" page: Untitled Document .
Gary Williams
Washington State
'67 GTV
Old 04-10-2008, 08:33 PM
vf31rhill's Avatar
vf31rhill vf31rhill is offline
Most successful rings for replacement regardless of piston make are Grant. They seat successfully about 100% of the time. When I was wrenching professionally I always used Grant rings even if it meant discarding the rings supplied with the new pistons. Wasteful, but beats having to deal repeatedly with customer unhappy with oil consumption/blue-black exhaust after spending major $$ on a complete engine rebuild. I understood that eventually the rings would seat and last a long time, but irate customers are not known for their understanding.
Robert Hill
Old 04-11-2008, 09:46 AM
Russ Bellinis Russ Bellinis is offline
Skip the warm up and drive, but don't hammer it until it is warm. The problem with warming an engine before driving is that the trans and rear end don't get warmed up with it idling in neutral. If you just warm up the engine and then take it out and hammer it, the cold thick oil in the trans and rear end are a problem. With Alfa's famous 2nd gear synchro problems, you want the gear box warmed up. Last year in Hemming's Sports & Exotic Car mag in an article on a drive in a Ferrari, the owner advised that he would skip shift from 1st gear to 3rd gear until the trans was well warmed up to keep from damaging 2nd gear while the tranny oil was cold.
