Roland,
There are considerable differences in the front of the car, but none that should prevent you from using parts from the 69 Spider. The 67 Spider didn't have a rear sway bar. So, you will need to make some mounts for the rear sway bar. All of the other stuff should bolt right up.
The engine compartment will be a little different in that there may not be mounts for a brake booster or clutch fluid reservoir. These things will need to be carefully removed from the 69.
Do not sell anything from either car until you have completed your restoration. If it were me, I would toss or give away the suspension bits from the 67. If you have an engine and transmission from the 67, sell that as well and sell the seats and dash. Keep everything else as spares.
As for the left over body bits from the 69, I'd keep those too.
__Oh Boy ____yeah ______wow ____cool ______yippie ____wahoo __yeah baby _pfffffffffffft
