#16 (permalink)
Old 10-17-2004, 04:28 PM
gotglasses gotglasses is offline
1stgear synchro.
Alfa spiders use Porsche (early) type synchros. The synchro clutch design does not work on 1st from neutral . It does work direct from 2nd or another gear, since you have to go through the neutral gate to make the 1st gear synchro do anything. Reverse , of course is not syncronized. Try going into first from second at a reasonable speed and compare it to going from neutral.
It always helps to make a little move toward 2nd at a light or when reversing, since you do have some parts spinning at all times.
  #17 (permalink)
Old 10-17-2004, 05:33 PM
JoeCab's Avatar
JoeCab JoeCab is offline
Sorry, bad advice.
I cringe every time I hear someone suggest this. Second gear synchros take enough abuse as it is - do not add to this by using second to slow the tranny so it will go into First.
As others have suggested, use Fourth or snap off a quick double clutch and it will go right in.
Joe
  #18 (permalink)
Old 10-17-2004, 05:39 PM
MyVeloce MyVeloce is offline
Originally Posted by rmatteo
Just a quick follow up. The problem was solved by adjusting the length of the striking rod on the clutch master cylinder. Shifting into first is now like butter hot or cold. Reverse is not exactly butter, but still much smoother.
Damn!!! This was going to be my suggestion. I just did it this weekend and what a difference.
  #19 (permalink)
Old 10-17-2004, 06:13 PM
rmatteo's Avatar
rmatteo rmatteo is offline
I wish you would have said something sooner! But alls well that ends well.
  #20 (permalink)
Old 10-17-2004, 07:26 PM
papajam's Avatar
papajam papajam is online now
with the Librarian
Originally Posted by papajam
Sounds like the clutch is not fully releasing.
How far off the floor is the clutch pedal when the clutch is fully engaged?
That's why I asked this question. No matter. Congrats on a successful repair!
Series 1 Euro 1750 GTV
Series 2 US 1750 GTV
Series 3 Spider Veloce
  #21 (permalink)
Old 10-17-2004, 07:46 PM
rmatteo's Avatar
Ha! It was that exact picture out of my new shop manual that helped me out. Or I just could have listened to Jim right from the start. Thanks Jim, I'll pay better attention the next time.
  #22 (permalink)
Old 10-18-2004, 10:39 AM
Grinding
Be a little careful adjusting that clutch rod. The throwout bearing may be the next thing you have to replace, along with a bent release arm (which may have been the cause of the problem to begin with). Hydraulic clutch cylinders pretty much self adjust within their range of movement. If you need to lengthen the rod more than spec look for wear and bending along the linkage.
While a noisy synchro is embarassing , it never left me stranded on the highway . The clutch linkage has.
