Old 09-19-2004, 07:17 AM
Don Don is offline
Question 88 Graduate Blown Fuel Pump Fuse
My 88 Graduate would not start. I have a blown Fuel Pump Fuse. Will check fuel pump and the voltage at the drive relay. Possibly main relay. Is there anything else I should check? Fuse melted right through fuse housing! Any help appreciated before I have to replace or repair pump.
Old 09-19-2004, 08:32 AM
denis's Avatar
denis denis is offline
Send a message via MSN to denis
Don,
Check for :
- Corrosion at fuse holder contacts : Clean. You may also change the fuse holder;
- Pump jammed (rust particles, etc. ) : Replace (I replaced mine a week ago and the car is now running);
- Short circuits : Repair
Preventive actions :
- Change your fuel filter;
- Check for rust, debris, etc. in your tank.
Good luck
Denis Plourde
'88 Spider Graduate
'00 Subaru Impreza 2.5RS
Old 09-19-2004, 08:47 AM
Roadtrip's Avatar
Roadtrip Roadtrip is offline
74 Alfa Spider
Check for shorts in the feed wire. If nothing, then it's likely that your fuel pump is well toasted.
John Stewart
74 Spider
Old 09-19-2004, 12:55 PM
Davy13's Avatar
Davy13 Davy13 is offline
When I replaced my fuse holder, I went with the flat, two-prong knife type fuse and holder. The holder is a thick rubber thing, with an air-tight cap. I was really pleased with it... Fuses blow for a reason, and I searched high and low for what the cause of my short was... I could not find anything, but all evidence (car stalled immediately upon hitting a puddle, and once it was eventually re-started, would simply refuse to run for any length down a rain-soaked road) pointed to the little rubber caps not covering the fuel pump contacts... I think that their exposure was the root of all problems. After cleaning them off and covering them correctly, then repairing the fuse holder, the car has ran like a top (actually seemed to have better performance than before)... Hope all goes well for you...
-Dave.
Old 09-19-2004, 04:41 PM
Don Don is offline
Great idea. I will try. Thanks.
