Old 09-18-2004, 04:02 PM
Privatejoker86 Privatejoker86 is offline
Darn you bleeder screw!!
So picture it...the place: my driveway. The time: yesterday.
I'm getting ready to bleed my slave cylinder. Everyone says to make sure the bleeder is at 12 o'clock. I can't figure that part out, but I start anyway. I just start to turn and CRACK, my bleeder screw is in half. Are these any kind of standard size?
Thoughts?
Old 09-18-2004, 05:20 PM
ossodiseppia's Avatar
ossodiseppia ossodiseppia is online now
pffffffffffffffffffffff!!
I don't see why you couldn't get one at NAPA. Did you get the other half out?
Old 09-18-2004, 05:32 PM
I haven't gone there yet. I hope I can, but I didn't want to pull the other half out since it wasn't leaking...yet.
Thought someone else might have had the experience and would know if it was an easily replaceable part.
Old 09-18-2004, 06:02 PM
JoeCab's Avatar
JoeCab JoeCab is offline
In my experience, the bleeder screw material is so soft that you can't use anything like an EZ Out (isn't that an oxymoron) on a broken one. If there is enough material sticking above the cylinder surface try to get a grip on it with vice grips or similar.
Old 09-18-2004, 06:03 PM
That's no good....there's nothing sticking out.
Old 09-18-2004, 06:30 PM
BigSwede's Avatar
BigSwede BigSwede is offline
MIG welder, weld a nut on there and just screw it out, the heat will loosen it to.
Probably will screw the seals though but it is the only method I've ever been successful with, have used it on probably 20 bleed screws on brake calipers 100% success rate.
Is that you John Wayne? Is this me?
Mats Strandberg
Old 09-18-2004, 07:42 PM
It's starting to look like you should just buy a new one. For all of the hastle that you're going to have to go thru and that fact that you may screw up the seals (if you have to heat it) it's not worth messing with just to save a couple of bucks.
Old 09-18-2004, 10:21 PM
sono veL.O.ce's Avatar
sono veL.O.ce sono veL.O.ce is offline
If you do buy a new one, you could then try to remove the offensive bit with the slave on your workbench instead of from underneath the car. If then you are successful, you'll have a decent spare, or something to trade.
since you'll be replacing the bleeder, consider getting one of the one-man speed bleeders, Its the same bleeding nipple with a check valve in it so you simply loosen and pump. no repetitive twist-pump-twist.
Or even better a pressurized bleeder tool from motive(?). I have one, and use it to keep the fluids fresh (once a year), I can do brakes at all corners and the clutch in less than 20min. without a helper. Its great.
Good luck!
Old 09-18-2004, 10:24 PM
Oooh, one more Idea! you could try to cut a cross in it with a dremel or something and then try to remove it with a phillips head screwdriver. Put some penetrating oil there the night before..
I feel for you man, I just hate broken hardware!
Once again, good luck!
Old 09-20-2004, 12:12 PM
Duke58 Duke58 is offline
Private Joker,
You had best sound off that you do love your Alfa...
