Doubtful it's an issue with the compressor. The blower fan will work with the switch even if the compressor is not working. My system is completely depressurized and I can still blow air out the vents.
Pic of the tubing is below. As you can see, there's four tubes that connect to the air box (one to each side vent, two to the center vents). I can't imagine they're all loose or blocked, so my guess is that it's an issue with the blower itself.
The blower is in the top of the passenger footwell. Are you sure it's turning when you turn on the fan? The sound you're hearing might be the compressor in the engine bay, I suppose. Get down there and play with the switch and see if you can figure out if the fan is working properly - that's your most likely culprit.
1991 Spider
1987 Milano Gold
