I rushed home to look at the tailpipe and found that I indeed have a straight, left-angled pipe. In looking through one of my spider books it is seems that the pipe should come just under the bumper, not past it.
Again, looking at the pictures, I there is a very early Kamm back with a straight pipe but thereafter all kamms up through the mid 80's (I'm guessing based on these pictures) had the down curved pipe. Two observations:
1) A Kamm is over 5" shorter that a boat (rear axle to bumper: 1065mm vs. 935mm) and presumably the tailpipe is reduced accordingly.
2) The Kamm tailpipe appears to be tucked up tighter against the bottom and has a cutout at the rear valance for clearance. The down curve brings the mouth of the pipe down to the height of the boat tail tailpipe.
It could be that the straight pipe was a problem all along and the engineers didn't find a fix until '71. Anybody have a boat tail that doesn't pull fumes (that is in stock trim)?
As far as the trunk seals are concerned, I am going to stuff the trunk with the car cover and what ever else I can find to fill it up. If the fumes go away then it's clear that it more of a seal problem. Really I can't see the trunk being a big contributer with the top down. Perhaps with the top up...
- Rich D.
