#31 (permalink)
Old 04-11-2008, 08:24 PM
gadwhite's Avatar
gadwhite gadwhite is offline
Senior Scottish Member
Reasons
Originally Posted by vf31rhill View Post
"The mystery is how the Master Cyl. rod got so badly bent." + "Teenage sons" = ?????
Any possible connection? This sounds like a classic case of "Son, how did you manage to get yourself into such a mess?
Robert
Robert
I or the PO are responsible for bending the rod. My pivot arm is incorrect ( Bad Weld). I am crazy(Alfisti), but not crazy enough to let my son take my beautiful Issabella out.
1985 Spider Veloce,
Now 2008 Honda Element
was 2005 Honda Element ,
  #32 (permalink)
Old 04-11-2008, 10:19 PM
Tifosi's Avatar
Tifosi Tifosi is offline
Slacker
LOL
I let my daughter take mine out for a hop to the store one evening last summer to nab some beverages and snacks.
She got about a block or so away before we who stayed behind heard the very distinct sound of the engine winding up to redline, a shift, then winding up again.
Apparently someone annoyed her and she sorta gave them a bit of show-n-tell, or at least that was her story when asked about it upon her return
Darren
as hosted by
  #33 (permalink)
Old 04-12-2008, 12:02 PM
gadwhite's Avatar
OK Started
Ok started the pivot shaft replacement, following these excellent instructions:
Replacing the Alfa Clutch Pedal Shaft
First removed the bolt holding the master cyl's to the body of the car and the pivot to fork cotter pin, then the pin through the fork and pivot.
Name:  Pedal Housing removal.jpg
Then the nuts from inside the engine compartment on the housing and the nuts from inside the footwell in the car
Name:  Pedal Housing removal1.jpg
I had a lot of difficulty getting the pedal housing far enough from the firewall ( Afraid of damage to brake and clutch hard lines), so I actually went from inside the car , upside down, under the dash, to remove the bolt securing the clutch pedal to the shaft . This seems marginally easier, but when I say marginally I mean marginally. You can just see it (11mm BTW) above the steering column
Name:  Clutch pedal removal from pivot.jpg
Name:  Clutch pedal removal from pivot1.jpg
The next problem I am working on, is the pin that goes through the pivot shaft indentation to hold the pivot in position, is stuck, I was unable to tap it out. So for now I am soaking it in PB Blaster, and will whack on it in an hour
1985 Spider Veloce,
  #34 (permalink)
Old 04-12-2008, 03:12 PM
ghnl ghnl is offline
That pin is tapered and will be a tight fit (until it comes loose...). To avoid having it fly off to places unknown when you tap on it and it suddenely come loose, leave the nut on the pin. That also helps avoid damaging the threads on the pin.
- - Eric
don't read this
~ 1984 Spider Veloce ~
Mebane, North Carolina
  #35 (permalink)
Old 04-12-2008, 07:24 PM
gadwhite's Avatar
good tip
Thanks, good point, I will actually put the nut back on, and work it.
1985 Spider Veloce,
  #36 (permalink)
Old 04-12-2008, 10:39 PM
gadwhite's Avatar
Pivot Pin and arm removal
Ok finally went back and decided to "follow/read the instructions" (RTFM). Managed to get the pedal housing up where I could work on it and got the pin out, and then the pivot arm.
Name:  Pivot Pin Removal.jpg
Name:  Pivot Pin Removal1.jpg
Here's what the pin looks like. Note it is bevelled, but only on one side.
Here is a comparison of the new pivot arm and the old one, obviously repaired by a lazy PO ( Incorrectly)
Name:  Good and Bad Pivot arm.jpg
OK tomorrow I will try to install the new one. I dont think this is going to be fun, but got to get it done.
1985 Spider Veloce,
  #37 (permalink)
Old 04-13-2008, 01:18 PM
gadwhite's Avatar
Got it in
Well I did it. Used these handy 45 degree long pliers to get the pin behind the clutch pedal attachment point then tightened everything up.
Name:  45 degree pliers.jpg
One problem I didnt anticipate is the IAP pivot is a little beefier ( wider) where it goes into the fork. They had also painted it pretty heavily, so I had to file off the paint.
Name:  Pivot clean up.jpg
I then measured 134 mm and hooked up the master cyl. and put in a new cotter pin.
Name:  New Cotter pin.jpg
Next Im going to bleed the system and see where I am. BTW here is the top of the clutch pedal where it is attached to the pivot.
1985 Spider Veloce,
  #38 (permalink)
Old 04-13-2008, 02:57 PM
Great photos! Thanks for posting them.
- - Eric
don't read this
  #39 (permalink)
Old 04-15-2008, 10:19 AM
gadwhite's Avatar
didnt work
Well Everything measures up correctly, the system is bled and I have 11-12mm of movement at the slave actuator, but still will not go into gear with the engine running. Looks like something is keeping the trans turning even when in neutral. The only thing I can think off is a damaged throwout bearing , because I have noticed a rattle , with the clutch disengaged (Pedal to the floor). Any comments, suggestions, before I pull the transmission?
1985 Spider Veloce,
  #40 (permalink)
Old 04-15-2008, 11:17 AM
Our transmissions don't easily go into first gear from a stopped position. My understanding is that isn't a synchronizer for the 'up shift' (N -> 1) although there is a synchro for the down shift (2 -> 1).
If you first 'touch' another gear (I usually use 3rd) to slow/stop the spinning gears then move the lever into first does that make any difference? If so that is quite normal.
- - Eric
don't read this
  #41 (permalink)
Old 04-15-2008, 11:33 AM
gadwhite's Avatar
Touching gears
I need to double check this, becuase usually this is how I get into reverse ( go to 1st to stop trans then to R, but right now though at a stop with the engine running I cant get into 1,2,3,or 4th, (a lot of grinding). If I start the car in gear I am able to let out the clutch and take off no problem from 1,2, and reverse.
1985 Spider Veloce,
  #42 (permalink)
Old 04-15-2008, 02:52 PM
And you are sure the actuating rod is adjusted to the correct length?
- - Eric
don't read this
  #43 (permalink)
Old 04-15-2008, 05:22 PM
gadwhite's Avatar
Actuating rod
Yep 134 mm, but will triple check, also may have spotted a slight leak. I get a new unit tomorrow, so will replace master anyway, but if the slave is moving the clutch fork the 11-12 mm this should be enough right?
1985 Spider Veloce,
  #44 (permalink)
Old 04-15-2008, 05:34 PM
yvesmontreal yvesmontreal is offline
I have seen this done voluntarily on a Spider, but the other way. The original owner was very tall, he wanted to move the pedals away.
I don't think your problem is with the throwout bearing. I had a seized throwout bearing on another car (Chevy Celebrity!!!) and it squeals like crazy!
Unfortunately, I think you may have a broken diaphragm spring on your pressure plate. The clutch still transmits torque, sort of, but when you try to release it the force transmitted through the throwout bearing has got nothing to build leverage.
There may be easier to fix hypothesis though.
  #45 (permalink)
gadwhite's Avatar
call me crazy, but..
I keep hoping
