03-16-2008, 02:58 PM
S3 1988 spider
Help!!!!!!!!!!!!!!!!!!!!!!
I am a new user to this forum
Have a S3 spider, just purchased, and was running rough on tickover. In haste, I undid the distributor clamp and moved the timing , now the car wont start. The distributor does not contain points. How can I re-set the timing to start the car please.
Also, have noticed that the vacum pipe is split. Could this be the cause of the car running rough at idle
Thanks Folks
03-16-2008, 03:10 PM
Thanks for the message
I have a Carb Model. Will this make a difference
03-16-2008, 03:25 PM
In the Spiders' nest...
Sorry, I thought you had a series 3 Bosch EFI Spider, which us what was imported to the U.S... EFI and carbs deliver fuel in a very different manner, although it's just a different way of feeding fuel into the engine, but still the write-up is for Bosch L-Jet... You may want to post in what part of the world you are located and whether your series 3 has a 2 liter or a 1.6 liter engine.
Best regards,
Enrique
Spider 74, 84 & 87
164 93L & 95Q
Milano 88 Verde
03-16-2008, 03:27 PM
Thanks again
I am based in the UK and the car is a 2000cc Carb Model model
03-16-2008, 03:30 PM
Yep that'll make a big difference.
Is the dist. a Bosch self contained electronic unit? Usually Bosch has a mark on the dist body and a mark on the tip of the rotor. With the engine at TDC for #1 cyl, those marks should align for basic timing. On the Bosch EFI cars that's all that's needed. Since your's is not EFI you may have to further adjust with a timing light.
BTW no matter what fuel system your car has, fix the vacuum leaks. Vacuum leaks are nothing but valve burning trouble.
Larry the Cable Guy
03-16-2008, 03:33 PM
I think it is
The distributor just has a rotor arm inside and a dust plate. Excuse my basic knowledge
There is a mark on the side of the distributor which appears to be for setting the timing
I wish I had left it alone as the car was at least running!!!!
Thanks for the help guys
03-16-2008, 03:44 PM
The mark is probably for setting the timing, and it isn't hard to do, but I would hate to just guess... I would suggest you get the appropriate manual on CD from Cardisc.
Best regards,
Enrique
Spider 74, 84 & 87
164 93L & 95Q
Milano 88 Verde
